Suspension or nitrous?
Old Dec 12, 2008 | 10:00 AM
1badzee's Avatar
Default Suspension or nitrous?
I'm in a dilema.. I can't quite yet afford a new cam swap so I'll have to suffice with my setup as is. BUT, in the meantime, should I get some suspension (subframe connectors, control arms/relocation brackets), or should i purchase a small single fogger setup? I kind of wanted the nitrous but some people said its pointless without suspension because im going to be hitting the wall at the track lmao. Any ideas?
Old Dec 12, 2008 | 10:02 AM
z28rob18's Avatar
you wont be hitting the wall i didnt on a 100 shot street tires and i didnt hav those parts. id go with the nitrous you'll lik it alot better
Old Dec 12, 2008 | 10:21 AM
SpeedDensityZ's Avatar
You should do the suspension first. Usually if you build the motor first you never get around to doing suspension and you never see the full potential of you setup. Look at me. I built the motor first. Now, I wish I had built the car from rear to front. I wouldn't be worried about breaking rearends, clutches, etc.etc.
Old Dec 12, 2008 | 11:00 AM
baylove's Avatar
either way your going to have to do your suspension if its before or after
Old Dec 12, 2008 | 11:01 AM
Black94Z28's Avatar
I agree, start from the back and work to the front. Rear end, suspension, trans...I did engine first on my last car. Had a high reving 355 with the factory 3.08 7.5 rear end that made the car a dog on the street. Then when i did put a rear end in the car, it would never hook up with the stock suspension.
Old Dec 12, 2008 | 11:05 AM
z28rob18's Avatar
but hes not talkin bout buildin a motor hes talkin about doin a few small suspension things or nitrous probably plannin on spendin maybe $500 id go nitrous and have some real fun then piece ur suspension together later. i see where ur all comin from but hes not talkin bout buildin a motor just a simple n2o kit
Old Dec 12, 2008 | 11:16 AM
LS1 SPEED's Avatar
does the car have any traction issues at all now NA? if not you can bet you will with N20 !
if it does have traction issues now then plan for more with N20
point is... I would suggest getting a few suspension things to aid with making the car work well with or without adding the N20 unless you like to do long burn outs
Old Dec 12, 2008 | 11:23 AM
impaled's Avatar
suspension for sure. you will have a hell of a time hooking on street tires with spray without some suspension upgrades, and if you are on slicks you have to realize that the 10 bolt may be on borrowed time.
i have BMR poly/rod LCA's and matching PHB, LCARBS, and koni's in the rear, i hook way better with just those few parts than i did on stock suspension, not even having spray or a cam.
Old Dec 12, 2008 | 11:26 AM
3DFORMULA's Avatar
My car is only suspension right now. Suspension first.
Old Dec 12, 2008 | 11:36 AM
robsquikz28's Avatar
just buy lca's and a panhard bar.....and still get the n2o thats all i had b4 and was cutting 1.57's all day on slicks...
Old Dec 12, 2008 | 12:23 PM
PNYKLR-TA's Avatar
rob everytime i go into a thread and see that avatar i just sit and total space out starring at that thing!
Old Dec 12, 2008 | 12:56 PM
Yep
Old Dec 12, 2008 | 01:07 PM
1badzee's Avatar
Yeah, I have issues hooking right now N/A even with my stock stall and radials \= Maybe I'll do suspension first. Like someone mentioned, it has to be done eventually, might as well do it now
Old Dec 12, 2008 | 02:47 PM
impaled's Avatar
if you cant hook now, spray wont do any good, or at least not as much good as getting her to stick on a launch.
Old Dec 12, 2008 | 03:08 PM
Elliott's94Z's Avatar
Suspension is always the first thing I dial in before any go fast parts. Suspension all the way...
Old Dec 12, 2008 | 03:16 PM
StealthFormula's Avatar
What good is power if you can't get it to the ground? Thats what I think so the smart thing is to do suspension first. Get what you have working well then add power once you have everything set up.
Old Dec 12, 2008 | 03:50 PM
koolaid_kid's Avatar
Rob, I have to admit I like that bubblebutt also.
OP, I did the engine first, now all I do is spin. I am in the process of improving the suspension before I put some real power down with the new engine.
If I had it to do over again, I would do the suspension first so I could take advantage of the added power when it came along. Live and learn.
Old Dec 12, 2008 | 03:59 PM
sweetbmxrider's Avatar
suspension first, it will in no way hurt you. plus there are some awesome deals being cut on here, who can resist!
Old Dec 12, 2008 | 04:19 PM
EliteCamaro94's Avatar
i say suspension as well, you have to get the power to the ground first. No use in gettin the spray if your just gonna spin tires down the road.
