lt1 power limit
Old Dec 14, 2008 | 11:01 AM
BRADP's Avatar
Default lt1 power limit
im building a 355 lt1 this winter with an AI rotating assembly, ported heads, cam, and 2 stages of nitrous. how much power can the stock block handle before i need to start getting scared. thanks for the help
Old Dec 14, 2008 | 11:14 AM
LSWHO's Avatar
Stock block will handle way more than you are giving it.
4 bolt?
Old Dec 14, 2008 | 11:19 AM
TwoFast4Lv's Avatar
I have seen over 600RW with a spot on very conservitive tune. it is a crap shoot. Some pistons giove out early
Old Dec 14, 2008 | 11:34 AM
FASTFATBOY's Avatar
Rick Intrau made 1200 rwhp with a stock LT1 block.
Old Dec 14, 2008 | 01:24 PM
TwoFast4Lv's Avatar
Ah I for some reason got confused. I thought he ment stock short block.
A FILLED block seems to have no problems pushing over 1,000RWHP
Old Dec 14, 2008 | 11:20 PM
MadMike 97 Z28's Avatar
would the stock block not hold 1,000 hp without being filled?
Old Dec 15, 2008 | 04:33 AM
monster81's Avatar
if ur planning for a big shot of n2o, i would suggest that u go forged everything (pistons, connecting rods and cranck shaft),,just to be on the safe side
Old Dec 15, 2008 | 08:58 AM
ScreaminRedZ's Avatar
registered user
Not too many people need to worry about how much power the actual block will hold, lol.
Old Dec 15, 2008 | 01:59 PM
PNYKLR-TA's Avatar
i was thinking the same thing, and im not saying this specifically to the OP but it seems like people come in here asking will my motor hold 7 hot side double lapped turbo's with 879 psi per cylinder with 6 stages of nitrous equalling 9billion hp.
then everyone starts in with everything they will need and their goals realisitically drop to about 400rwhp.
Old Dec 15, 2008 | 02:01 PM
PNYKLR-TA's Avatar
so in other words you will be fine, just go all forged. and you can pretty much do whatever your little heart desires, as long as your wallet can afford it.
Old Dec 15, 2008 | 02:05 PM
AChotrod's Avatar
Im sure hes asking because other blocks tend to be the weak point. HHHmmm.. cough... cough... 5.0 motors... cough.... cough..... my buddy blew the entire front out of his 5.0 block and it is considered a weak point past a certain HP
Old Dec 15, 2008 | 02:10 PM
PNYKLR-TA's Avatar
there is actually a 5.0 running around phoenix with a decent sized shot of nitrous, he had blown his intake manifold into peices i think 2 times now.
makes me laugh everytime. i think its on a 200 or 250 shot too.
although when the car does run it is pretty damn fast.
Old Dec 15, 2008 | 02:18 PM
TT632's Avatar
Over 500 rwhp on a stock 5.0 block, and you are living on borrowed time. You can get away with it, but they like ejecting cranks out the bottom. Do an internet search, you will find pics all over.
Old Dec 15, 2008 | 02:33 PM
AChotrod's Avatar
Thats exactly what happened to my buddies 5.0 spit the crank right out the front of the block destroying everything in its path.
Old Dec 15, 2008 | 02:37 PM
BRADP's Avatar
yea its going to be a completely forged rotating assembly, ported heads, cam, and about 200-250 shot of juice goin at it. it will get tuned of course but i dont want the stock block to be the problem since im dumping mad money in it.
Old Dec 15, 2008 | 02:47 PM
AChotrod's Avatar
you should be fine with the block just get splayed main caps on it
