Need help
Old Dec 15, 2008 | 11:25 PM
lsuchamps2005's Avatar
Default Need help
For some reason my Fans just keep kicking on and then off.. My car isn't running hot at all, unless my temp guage is off, even when i first start the car the fan starts kicking on and off. If anyone has any ideas would be greatly appreciated.
Old Dec 15, 2008 | 11:28 PM
fergymoto's Avatar
Is it a 1995 or earlier car? Does the SES light come on when the fans do? The fans will run when a code is thrown on OBDI cars.
Old Dec 15, 2008 | 11:32 PM
No it's a 97.. And it isn't throwing any codes..
Old Dec 15, 2008 | 11:35 PM
IronOutlaw's Avatar
I know the fans are supposed to turn on when you run the A/C, but im not sure if they are supposed to come on right when you crank the car.
When you run the defroster the A/C pump comes on and triggers the fans, maybe that is it???
Old Dec 16, 2008 | 06:39 PM
96LT1Camaro's Avatar
you can do what i did and just run a cable from the battery to the fans splice it to a ground then to a toggle just make sure you have a fuse and your good to go
Old Dec 17, 2008 | 01:54 AM
robsquikz28's Avatar
any luck yet.....you can possilby have a stuck relay that turns and keeps the fans running...
