A4 to M6 swap help please
Old Dec 17, 2008 | 11:38 PM
1badzee's Avatar
Default A4 to M6 swap help please
I need a write-up with step by step wiring instructions with pics if at all possible for an A4 to M6 swap. I searched, and searched. Most of the results are for LSX cars and the wiring is different in those cars. I hope I'm not being too picky I will be using my factory A4 harness..
Old Dec 18, 2008 | 12:25 AM
MEAN LT1's Avatar
The best wright up ever.
http://www.afrashteh.com/tranny_pics/T56.htm
Old Dec 18, 2008 | 12:41 AM
the_merv's Avatar
^^I think mine's right about there, if not a little more easier to understand with the Wiring..
I did the swap into my '95, and used an A4 Harness to do it. I know the LT1 has a different Harness, but you can do with yours what I did with mine, and it will work. You will just have to do a little research to find out what Pins are what on the LT1 PCM Connectors.
All I have left is installing everything when I get back. If you saw the Car now, you would think it was a Standard from the Factory.
Here is my thread..
MY T56 CONVERSION
