going 1st gen sbc need help
https://ls1tech.com/forums/small-blo...lt1-f-car.html
I removed the injector wiring, MAF, O2 sensor wiring, IAC, TPS, IAT and everything else i would no longer use. I used all the stock sensor wiring. I had to use a third gen water pump and serp system since the brand new electric water pump i wanted to use burned up in 20 seconds and the plumbing is too close to the belt.
