30# injectors, stock pump
im not sure exactly what my tuner did while he was in there but long story short i had a bad opti and couldnt fully tune the car. the rev limiter is disabled and skip shift is disabled. those are the only things i know for sure have been done. i have tryed putting a few different stock replacement pumps in and it helped for like a day but that was about it.
it only happens under WOT. if i lift my foot off just a little it wont do it at all. it happens from about 5500-6500. the car has the stock fuel pump and wiring with brand new new style red top injectors, new acdelco fuel filter, it had a delfi pump in it and i replaced it with an airtex under warrenty.
im short on cash and want to get the car retuned and i want to know if a pump or hot wire kit is necessary. anyone have any experience with this?
If the pressure stays steady then the pump is fine.
Fuel filter is quality and new?
All grounds good?
r all the hoses connected at the pump????and the charcoal canister...are there any pinched rubber hoses after the pump or did you or could u have cut the hose in the pump accidentally......definately a fuel issue
