96 TA Questions
Length: 197 in.
Width: 74.5 in.
Height: 52 in.
Wheel Base: 101.1 in.
Ground Clearance: 4.4 in.
Curb Weight: 3477 lbs.
Front Head Room: 37.2 in.
Front Hip Room: 52.8 in.
Front Shoulder Room: 57.4 in.
Rear Head Room: 35.3 in.
Rear Shoulder Room: 55.8 in.
Rear Hip Room: 44.4 in.
Front Leg Room: 43 in.
Rear Leg Room: 28.9 in.
Luggage Capacity: 12.9 cu. ft.
Maximum Seating: 4
Base Number of Cylinders: 8
Base Engine Size: 5.7 liters
Base Engine Type: V8
Horsepower: 285 hp
Max Horsepower: 5000 rpm
Torque: 325 ft-lbs.
Max Torque: 2400 rpm
Maximum Towing Capacity: 1000 lbs.
Drive Type: RWD
Turning Circle: 40.1 ft.
And yes it has the LT1
Length: 197 in.
Width: 74.5 in.
Height: 52 in.
Maximum Seating: 4
Horsepower: 285 hp
Torque: 325 ft-lbs.
Drive Type: RWD
Please tell me you did not have that all memorized
heres some more info
Week 10 bolt rear end. Stock gears should be 3.42
uses an opti spark(distributor) alot of us have problmes with them
revers cooling. this is where the coolant goes into the heads before it goes into the block.
And best of all, our cars like to kill mustangs
That's from Edmunds
