Timing Chain
Old Dec 20, 2008 | 05:37 AM
Airplanedoc's Avatar
Default Timing Chain
If I run an electric water pump can I run any timing chain set?
Old Dec 20, 2008 | 08:50 AM
shbox's Avatar
Any SBC type that is made for use with the late model roller cams. The Cloyes 9-3145 is a popular choice for a double roller. You may have to slightly clearance your timing cover.
Old Dec 20, 2008 | 10:04 AM
Elliott's94Z's Avatar
Just stick to the stock one and buy a new replacement from GM Parts Direct. $35..no need for a dbl roller. The stock timing chains hold up just fine.
