LE2 heads/cam
Injectors are
Is a fuel pump or boost a pump?
timing chain probably recommended?
Rockers
guideplates
pushrods
What am I missing?
Also anybody know if the lift numbers on the cams on the site are for 1.6s? I assume so.
I'm trying to put together a possible shopping list.
30# injectors
headgaskets,
new head bolts
lots of thread sealant
intake manifold gaskets,
waterpump gaskets,
timing chain cover gaskets and seals
new valve cover gaskets if yours are old.
coolant,
oil.
oil filter
RTV sealant for the intake manifold
cam lube
lifters if your engine has a lot of miles on it
if your feul pump is still working i wouldnt worry about it. its not necessary.
Injectors are
Rockers
guideplates
pushrods
What am I missing?
Racetronix fuel pump
New timing chain (no need for a dbl roller/heavy duty)
1.6 rockers self aligning (no need for guide plates with the self align rockers)
Autolite 104 spark plugs
pushrods, locks, shims, retainers
ls7 lifters
Bigger throttle body 58mm if you do heads and cam
Might not be a bad idea to have the intake ported as well
all the ness gaskets
