Roller Rocker question...
Old Dec 26, 2008 | 03:26 PM
Ihasfip's Avatar
Default Roller Rocker question...
I searched and couldn't quite find what I was looking for. I have the CC306 ( I know, I know) I do love it though. Anyways, I was going to do roller rockers as I have the stock rockers on now. My question is will 1.6 rockers and that cam work with the stock pistons? Is there any risk of valve/piston contact. I don't know what the max lift the stock heads/pistons will handle. Also what all is required? Just hardened push rods, NSA roller rockers and guide plates? There is no machine work involed correct? Thanks
D
Old Dec 26, 2008 | 03:31 PM
96lt1m6's Avatar
PM sent
Old Dec 26, 2008 | 03:32 PM
StealthFormula's Avatar
You will be fine and theres nothing wrong with that cam at all. For that cam I would go the NSA route. Pick up some Comp Cams Pro-Mag NSA 1.6's (1305-16), some TFS Guideplates (30400623-8), ARP Studs (134-7103) and some TFS chromemoly pushrods. The length of the pushrods may or may not be the stock 7.200" so good to measure first.
Old Dec 26, 2008 | 03:36 PM
Ihasfip's Avatar
And for the studs? Are the stock lt1 screw in 7/16?
C5042081's Avatar
going to 1.6 ratio will put more lift on the valve springs/valve train, I dont believe a 306 will affect piston clearance.
1.6 rr/ guide plates is a direct bolt on no mahcine work required.
Since you will have the pushrods out i would suggest swaping to hardened, and also check to see if your valve springs will handle the extra lift
Old Dec 26, 2008 | 03:40 PM
Ihasfip's Avatar
I have new PAC springs. I am sure they will handle the lift. I believe they are good for 625 lift.
D
Old Dec 26, 2008 | 04:01 PM
shbox's Avatar
All LT1 studs are 7/16-14 on the bottom.
Stock studs are 3/8-24 on the top.
7/16 studs are 7/16-20 on the top.
Old Dec 26, 2008 | 04:48 PM
ss.slp.ls1's Avatar
^^^Do exactly what he said.
I have all that mentioned above with a CC503 cam.
Old Dec 26, 2008 | 05:32 PM
Ihasfip's Avatar
Well that may have to wait. That is a little bit more money than I was thinking. That is somewhere around 550$. Versus a cheaper set with pushrods, guidplates, and studs for 380$. Anybody know anything about PEP roller rockers?
D
Old Dec 26, 2008 | 08:18 PM
96lt1m6's Avatar
here are PEP rockers,1.5chromoly
