starter question
Old Dec 27, 2008 | 03:23 PM
EliteCamaro94's Avatar
Default starter question
hey guys i got a 94 z28 and my starter went out today. How hard is it to change it? I never did it on this car the only car i ever did it on was my 79 z28.
Old Dec 27, 2008 | 03:29 PM
the_merv's Avatar
Not hard at all, just 2 Bolts on the side of the Block. Maybe a little tight as far as clearance.
Just dis-connect the Battery first.
Old Dec 27, 2008 | 03:31 PM
robsquikz28's Avatar
x2^ you will need a 9/16 socket with long extension and a 5/16 1/4 socket for the little nuts on there...and disconnect batt. first.....
Old Dec 27, 2008 | 03:33 PM
Captainofiron's Avatar
yea its really easy, like at most 30 minutes
counting the battery and wires you have to remove 5 nuts and bolts
only problem will be working around your pipes, but you can take it out with the exhaust in place
Old Dec 27, 2008 | 03:40 PM
BizZzatch350's Avatar
Moderator
If its an auto, remove the converter dust shield to gain some more access.
Old Dec 27, 2008 | 03:51 PM
yeah its an auto, my biggest issue is i have big *** hands and they dont fit anywhere in this engine bay area. Maybe i can get my little buddy ben to give me a hand. He is small enough to fit everywhere lol. Thanks guys. How much do starters usually run? like around 150
Old Dec 27, 2008 | 03:55 PM
Moderator
Some thing like that, check A-zone, I just picked up a Duralast with a life time warranty on it not to long ago, think it was 186$ with tax?
Old Dec 27, 2008 | 04:11 PM
96lt1m6's Avatar
i have an unused starter from autozone for 100.00 shipped
Old Dec 27, 2008 | 04:16 PM
why did you never use it? im in phx az how long would it take u to ship it here? I need it this week.
Old Dec 27, 2008 | 07:55 PM
buffman's Avatar
I see no reason it won't fit as an LT1 is an LT1, but get the Corvette Spec'd Starter from Autozone. Small, cool sound, lightweight, Lifetime Warranty. $120 + core. Just bring your core back another day... I'll have to double check threads, but I see no reason for it not to fit.
Old Dec 27, 2008 | 08:50 PM
ABA383's Avatar
Yeah the starter for a '96 Corvette, dubbed the LT4 starter, is a nice upgrade and fits with no problems...I run an AdvanceAuto LT4 style on my car and it works great...
--Alan
Old Dec 27, 2008 | 09:26 PM
buffman's Avatar
yeah i think it's been superceeded as it's listed for any LT1/4 vette at the store. I like the duralast unit better. Cheap I think too.
Old Dec 28, 2008 | 02:40 AM
the_merv's Avatar
I had a Corvette Starter on my LT1 when I had it. It worked really well.
He won't necessarily have to do that if it's already done, just pull it off of the Car and bring it in.
Old Dec 28, 2008 | 11:33 AM
96lt1m6's Avatar
spare for my 95 however it is going LsX
ship on monday you should have it by wed.
Old Dec 28, 2008 | 12:13 PM
joelster's Avatar
When my starter went, I replaced it with one of those tiny/high-torque starters, that weigh under 10lbs. A SBC starter will fit too as long as you get the same flywheel tooth count. I figured since the stock starer was around $150 i might as well spend another 20 bucks and save 5-10lbs while I'm at it.
Old Dec 29, 2008 | 11:27 AM
So u guys are sayin I can go to checker or autozone and get a 96 vette starter and it will bolt right up and be a better upgrade?
Old Dec 29, 2008 | 11:45 AM
connexion2005's Avatar
Fwiw I bought my starter off eBay the other day and it starts up my 12:1 compression just fine. I can't speak for endurance yet but 2 weeks and its going strong...
Oh and for your car they are only $70 brand new.
Old Dec 29, 2008 | 03:25 PM
any know for sure if the vette starter will work for sure
Old Dec 29, 2008 | 04:40 PM
nobody got any for sure info?
Old Dec 29, 2008 | 05:03 PM
I think the lt4 starter has a different ratio for better cranking if I'm not mistaken...
