lt1 runs on ls1 computer using modded OPTI
Old Mar 3, 2009 | 05:36 PM
  #181
Jditlfm's Avatar
Why not just look at tunner cat files and copy paste them over. or at least they will be a good reference to copy from and enter manually? I have tunner cats and hp tuners on my home computer so I might do some messing around.
Old Mar 3, 2009 | 05:58 PM
  #182
schwoch1's Avatar
You can do that on the fuel tables, but the spark tables on the LT1 are MAP -vs- RPM and the LS1 is RPM -vs- Grams of air per cylinder. I am going to run my engine on the dyno and see if I can kinda get the spark tables figured out!!!
Unless I was reading something wrong with my cal I have, the LS1 Camaro cal only had approx. 25 degrees of timing in the higher RPM/load range (higher KPA of Vacuum), which doesn't seem right to me, I can see that the LT1 has 30-32 degrees in what I would think is the same spot on the chart!!!
Mike
Old Mar 3, 2009 | 06:11 PM
  #183
AKAFRED's Avatar
lokked at doing this and the numbers wernt even close on the ve tables to what the ls1 tune had. also the rpms were diffrent and i think the map numbers were diffrent. also i use efilive..
Old Mar 3, 2009 | 06:59 PM
  #184
Jditlfm's Avatar
As far as the firing order being off are you just re pinning that or doing it in efi live. I have not found the tables to do it hp tuners. I am thinking though at this point i could just get a cam with the ls1 firing order when i make the switch and not have to re pin or worry about computer issues.
Old Mar 3, 2009 | 07:14 PM
  #185
AKAFRED's Avatar
without the cam you have to repin the harness either way..
look for injector bank assignment. this is what tells your pcm what side of the motor the fuel is being injected to. without this closed loop may suffer as it would be adding fuel to the wrong bank on switched cylinders.
Old Mar 3, 2009 | 07:22 PM
  #186
Jditlfm's Avatar
Thank you i appreciate the help. But I was asking about hptuners because that is what i have. I dont think hp tuners has those tables?? Now what your doing with efi live is just re arranging the injector assignment so the pcm will see them on the right bank but it still does not correct the firing order of the injectors or spark??
Old Mar 3, 2009 | 07:39 PM
  #187
AKAFRED's Avatar
the pcm is hard wired that the ouputs fire in the order that they fire in.. you have to wire accordigly. the reason for this table is to let the pcm know what bank you wired its outputs to..
i also relized that you had hptuners.. i dont thou i have efi live. i was showing you where it was in efilive in hopes that it was similar in hptuners..
i guess if someone had both efi live and hp tuners they could change those settings using efi live, write them to the pcm and then read the pcm with hp tuners.. only problem is that any custom os may erase these settings.. and you would waste 2 vins...
Old Mar 3, 2009 | 07:42 PM
  #188
Jditlfm's Avatar
ok i see what your saying now. I will keep looking supposedly these tables are in here or they are common out with an updated version. I might not digging hard enough.
Old Mar 3, 2009 | 07:46 PM
  #189
AKAFRED's Avatar
like i said eariler in this thread i would reccomend efi live if you havent allready purchased your tuning package..
if you allready have hp tuners they may be able to make these changes for you. i have read they will swap 4l80e tranny segments for users. (in efi live the user can do this)
Old Mar 3, 2009 | 09:11 PM
  #190
schwoch1's Avatar
I dont belive that HP Tuners has that table, but I am not 100% sure!!!
Mike
Old Mar 3, 2009 | 09:45 PM
  #191
CptMidway's Avatar
I hope they do... a buddy of mine has HP tuners, and I was hoping to have him help me with the tuning.
Old Mar 22, 2009 | 11:39 AM
  #192
InjectedSS's Avatar
HP Tuners does have the Injector Bank Select it's available in the newest beta version.
Old May 24, 2009 | 07:48 AM
  #193
schwoch1's Avatar
I am not trying to start a firestorm but.............. Is there any new news on this project?????
Just curious!!!
Mike
Old May 24, 2009 | 09:02 AM
  #194
FASTFATBOY's Avatar
I got a few questions, I have been watching this thread and the other one very closely.
Getting the crank position from the cam is easy...from a math standpoint. The cam is turning 1/2 as fast as the crank, So its cam signal times 2 for crank position right? Or divide by 2, hell I cant remember.
Heres the rub I see, If you degree a cam, advance a cam, retard a cam, aftermarket crank that is NOT indexed. Natural cam chain and gear wear. What happens on decel with a worn chain? How do you KNOW where the crank timing is? I mean REALLY know? Is there a way to "synch" it when you get all the cam degreeing done? Does it matter?
Hey I am no Guru, Im just askin'.
Old Jun 17, 2009 | 12:07 AM
  #195
Anthony0908's Avatar
Ide like to know where this ended up?
Old Jun 17, 2009 | 07:55 AM
  #196
duh's Avatar
duh
^+1, Me too.......
Old Jun 17, 2009 | 08:55 AM
  #197
schwoch1's Avatar
I asked a couple of weeks ago, never got any response. I am assuming it is a dead project? Kinda sad, I really would like to of seen it go!!!
Mike
Old Nov 3, 2009 | 03:13 PM
  #198
FASTFATBOY's Avatar
Has this gone completely kaput?
I wanted a cheaper option than the EFI connection, if possible.
Old Nov 3, 2009 | 03:21 PM
  #199
schwoch1's Avatar
I would have to say that this is a dead duck.......... Have asked the same question in the past and never got a reply, good bad or indifferent!!!
Mike
Old Nov 3, 2009 | 04:14 PM
  #200
gregrob's Avatar
He's replying right now! lol
