Alternator Whine!!!
Use a screw driver or a longer ratchet extension, make a fist right around the handle/end and then place it on the metal of the alternator (while the car is running and the whine is happening). Then put your ear to your fist (ear to thumb/index) and this'll act as a poor mans stethoscope. If the whine is not VERY loud when it's on the alternator, it could be the PS pump. Not sure if you can use a longer extension to reach the PS pump or not, and repeat this step, but you're welcome to try. This trick also works for other things where it's kind of hard to pinpoint the sound, like ticking if it's a rocker and what side, just put the 'stethoscope' on the valve cover
BUT It could also be the alternator, drive it to a parts store and see if they have a tester for in the car. Otherwise, just pull the alternator and take it in for testing.
