Comment on my LT1 Build!?
What do you guys expect from this combination.
Eagle street/strip rotating assembly .020 over
comp cams 233/239 112+3 LSA .569/.577 lift w/ 1.6s
Pro mag 1.6s SA
Crane springs(dont remember part ## offhand)
Hardened pushrods
Cloyes Timing set
Heads milled .005 to true the plane
3 angle valve job and light porting w/ port matched intake
K&N Cold air/1LE elbow
Hooker LTs w/ 2.5" true duals dumped at axle
MSD Coil
Racetronix 42 lb injectors
Racetronix fuel setup w/ walbro 255lph
Going to go with one of Ions tunes until I can afford a dyno tune
I think thats about everything. I may have forgotton something.
Do you guys think I can avoid upgrading the fuel pump for now?
What about the stock throttle body? Will I be losing power with it?
Let me know what you think about it.
It will be through an A4 with a 3200+ stall and 3.23 10 bolt.
From what I've heard you can skip this for now.
I was planning to have it tuned for the E85 when I go to the dyno.
The heads were not flowed. They were done by a reputable local shop. Just a mild port job. I wanted to get them flowed but at the time they had installed them before I had a chance to take them to a flow bench.
You should also be able to find a 52mm tb for 150-200, which on a motor like yours should be 10-12 hp. Depending on how much headwork you have you may want to pick up a 58 instead.
With the n2o use i would also go 3inch td's with an x pipe. The extra flow will help out, or keep the 2.5 and run cutouts.
