real quick question on deleting ac
Old Jan 2, 2009 | 09:00 PM
shutzero's Avatar
Default real quick question on deleting ac
do you take out that radiator looking thing in front of the actual radiator when deleting the ac?
Old Jan 2, 2009 | 09:06 PM
Stroked96Bowtie's Avatar
Yep thats the condensor. Does no good without the rest of it.
Old Jan 2, 2009 | 09:33 PM
RamAir95TA's Avatar
Leaving it in won't hurt, but for complete removal it's gotta come out.
Old Jan 2, 2009 | 09:42 PM
shutzero's Avatar
What about the plastic piece over it?
Old Jan 2, 2009 | 09:46 PM
RamAir95TA's Avatar
If you're talking about the radiator support (big black plastic piece you see when you open the hood with the labels and such), yes you need it!
Old Jan 2, 2009 | 09:49 PM
sprayed5oh's Avatar
Yup you need the plastic peice,it holds the top of the radiator.
Old Jan 2, 2009 | 09:53 PM
shutzero's Avatar
The one going over the top of the condensor?
Old Jan 2, 2009 | 09:55 PM
RamAir95TA's Avatar
See above.
Old Jan 2, 2009 | 10:06 PM
sweetbmxrider's Avatar
the one in front of the condensor towards the nose of the car should be replaced after you remove the condensor. it helps direct air flow over the radiator to keep the car cool
the_merv's Avatar
Yea, leave the black plastic piece. You will have to take it off to remove the Condensor, but put it back inplace.
Old Jan 2, 2009 | 10:17 PM
shutzero's Avatar
Its not the shroud with the labels on it...
Old Jan 2, 2009 | 10:24 PM
RamAir95TA's Avatar
Perhaps a picture would help with what you're talking about....
Old Jan 2, 2009 | 10:38 PM
i know what you are describing, replace it after you remove the condenser. like i said, it helps direct airflow over the radiator.
Old Jan 3, 2009 | 01:50 PM
robsquikz28's Avatar
yes keep it in its the lower splash shield but the time directs air to the radiator leave it in
