Timing Dropping
Old Jan 8, 2009 | 12:46 PM
ats5424's Avatar
Default Timing Dropping
Ok just changed the headders on my 95 formula m6. (Pacesetter Long tubes Painted). Car runs fine at idle and when cruising. When engine is put under heavy load the engine misses. I hooked it up to the datalogger and it shows that timing is dropping off when i give it a little too much gas. If I am just driving normally it runs like a champ. Wires have been checked over and over again and the plugs have only 5k on them. I unpluged the O2's and still the same problem. Need a little help.
Old Jan 8, 2009 | 02:08 PM
ss.slp.ls1's Avatar
The only thing the data logger shows that's abnormal is the timing, nothing else?
How long did you drive it with the o2's unplugged?
I have read that you can (for testing purposes only) unplug the knock sensor, hook up a resister to it (don't know the impedance) and ground it to the block. That will tell you if you are getting knock retard from the knock sensor.
