First runnin' on new 4.10s
The first thing I noticed was she broke loose out of the hole for the first time since I installed the Mickeys and she STILL posted an 8.06-1.78... I had been running 23 lbs, so immediately took it down to 17 lbs which solved the problem, except for one small squeak, which I attribute more to my being askew of the groove when I staged up on that run...
Second run was 7.98-1.78 and we stayed there pretty much for the rest of the night.
The second thing I noticed was that the tune/set-up had changed dramatically.
She now tickles the rev limiter coming out of first and smashes against it from second/third, which now comes up at about 450'. Before, she crossed thru the trap at the high edge of second; if I stayed in it, she would shift into third just as I crossed thru the time-boards... probably 30' beyond the trap laser.
The third thing, as I eluded to above, is that she hangs in second WAY too long... she's nosing over badly at the top of second before she pops third, she's just hanging there...; so I've no doubt that this is costing us big in ET. It's the same for first to second, just not as bad, so combined, I'm guessin' this could be as much as a tenth.
She has however blown the paper header-gaskets now (kids, this is one of those rooky 'mistakes' that the gurus will elude to when you're inquiring about doing your first rebuild ... GET THE ALUMINUM CRUSHERS!) and while I'm fixing that I am going to send the PCM back to Bryan at PCM-for-Less and have him change up the tune to accommodate the 26" Mickey's and the 4.10s. I expect that will put us where we need to be for the moment...
I've seen a lot of comments by guys on this site and others who have waved people off the 4.10s... and some that have installed the 4.10s and said they didn't really see a lot of change in ET with the 4.10s...
I'd just like to speak to those for a moment... I think that the tune is the reason is why the new 4.10 drivers are having problems... My Speedometer is WAY off now; looks like 20-25%, so anything that computes with consideration of the indicated speed is going to be screwed up, so a re-tune is mandatory, as far as I can tell.
As to the waving off of the 4.10 set-up... First let me say that my primary goal is 1/8th mile ET and heads-up 1/8th mile drags... Second, I DO, on rare occasion, enjoy some light 'street fishin;' low-end, light to light, 0-60 kills... because, well... they're just 'ma thang...' I'm decidely not interested in or concerned with fuel mileage OR highway cruising...
So, with that said, let me just say... I am LOVIN' THE 4.10s...
VIVE LE DIFFERENCE!
1st now comes and goes in a neck snapping moment... second remains a power-house and 3rd gear is DEADLY... drop her into 3rd and @ roughly 55 she sits at 3500ish rpms; so she is right in the 'pardon me while I kick your ***' zone... from 55mph in 3rd, it's unlikely you'll be offended by too many fly-bys, assuming you've some warning; at 3500 rpms ya just throw the hammer and stand the f&*#^ by for heavy acceleration... 'Sheeees GONE!
I think the re-tune will get us back in the hunt in the mean time...
Also, after I fixed the header gaskets last night, I found she's developed a knock... sounds like bottom end, but it disappears under load and the oil pressure is rock solid... any ideas?
First thing I would do is double check the oil pressure with a mechanical gauge - there is a nice empty spot on the 94+ right above the oil filter, which is where the factory sensor is on the 93's.
header tube size is a bit large at 1-7/8(for the set up)
2500 stall is barely enough to satisfy a stock Lt1
of course the lack of tune as mentioned prior
It was late when we finally got the crushers in and tightened down... so all I was able to do was throw a scope on the top end and that was inconclusive...
I'll post what we find out, when I get back.
In the mean time I've got this knock to work out, which is killin' my 4.10 buzz...
