high volume oil pump with stock oil pan???
but I think this topic was about stock oil pan with HV oil pump and people think they will suck it dry, not really about what pump they should run?
On my last engine only lasted 22,000 miles it was my fault for not checking the spin on adaptor bypass valve got stuck open so pretty much I was runing dirty oil through my motor fo the whole 22,000 and my pressure was always low(blamming the stock gauge)
but with my new motor I wanted to get a HV pump and forget about low pressure I got the Melling 10555 very nice pump it probabaly more volume then I need but its in and I don't plan on taking it out I already have 3,000 miles on her and so far its been good..
I check everything now I cut my filter.look good at my mag oil plug, and dirtynest of my oil and everything is ok..
i'm getting around 55# around 2000rpm and idle around 25#
I did switched to 5-30 wt oil and it don't get cold here in so cal, so I should be ok.
