what converter do i use for a th350?
Old Jan 14, 2009 | 04:37 PM
Taubr Unit's Avatar
Default what converter do i use for a th350?
performabuilt said i cant use a sbc converter and i cant use a lt1/4l60 converter in a th350. So what one do i use? What one should i ask for, a gen1 sbc or a lt1?
Old Jan 14, 2009 | 04:40 PM
Tapout911's Avatar
All that matters is transmisson and flywheel bolt pattern for the convertor to bolt to. As long as it is splined right on the tranny side and the tabs welded to it will line up with the flywheel holes, you can use it.
Old Jan 14, 2009 | 04:43 PM
Taubr Unit's Avatar
thats what i was thinking. Does anyone know if a 4l60 spline count is the same as a th350? considering they are stock spline count.
Old Jan 14, 2009 | 05:01 PM
fergymoto's Avatar
You need to get a TH350 converter. They make flexplates for one piece seal motors with the TH350 converter bolt pattern.
Old Jan 14, 2009 | 05:06 PM
tomcowle's Avatar
I used a th350 convertor on a stock lt1 flexplate, no issues.
B&M 10" convertor, its for sale really cheap
Old Jan 15, 2009 | 01:21 AM
95z28camaro's Avatar
Yep same here! Regular TH350 converter bolted straight up!
