short stick.
Old Jan 19, 2009 | 01:40 AM
6spdscreaminchickin's Avatar
Default short stick.
ok im clueless on how to put this thing in i got it from hawksthinrdgen.com and its cut at an angle???? they might have packed it wrong but i thought i would ask you guys first. the only thing i can think of is if you take the stock stick out of that little ring thing its in and put the short stick in their but i cant get it out and everyone ive asked so far siad thats not it. any ideas?
Old Jan 19, 2009 | 09:48 AM
z_speedfreak's Avatar
im not sure I understand what your asking but, remove the outer rubber boot and you'll be able to see where the stick is bolted to the shifter. hope it helps
Old Jan 19, 2009 | 03:00 PM
no. i'll put up some pics. i think they sent me the wrong stick. its not a short shifter its just a stick. i took the boot off and the stock stick. then i went to put the new one in and the flat side is cut at an angle. so if i bolt it on one side i cant shift into reverse or 6th without hitting the sides of the center consul. but if i bolt it to the other side same thing but with 1st and 2nd. like i said i'll put up some pics and maybe that will explain it better.
Old Jan 19, 2009 | 03:14 PM
AChotrod's Avatar
Is it made for a aftermarket shifter or stock hurst??? I dont think it will work on a standard shifter.
Old Jan 19, 2009 | 03:52 PM
Camaro/Firebird T-56 (6 speed) Short Stick for 6 speed shifters that have a removable stick, Most Hurst, SLP and Pro 5.0's, designed for better and quickershifting (results vary with driver), shipping is not included.
thats the quote from the site. stock shifter is hurst right?
Old Jan 19, 2009 | 04:06 PM
MTBSully's Avatar
[QUOTE=6spdscreaminchickin;10879490]Camaro/Firebird T-56 (6 speed) Short Stick for 6 speed shifters that have a removable stick, Most Hurst, SLP and Pro 5.0's, designed for better and quickershifting (results vary with driver), shipping is not included.
thats the quote from the site. stock shifter is hurst right?[/QUOTE]
wrong.
hurst shifters are not stock unless you have some versions of the ws6 or the SS
Old Jan 19, 2009 | 04:17 PM
AChotrod's Avatar
[QUOTE=MTBSully;10879584]
wrong.
X2. Hurst is not stock it was only on some SSs and WS6s
Old Jan 21, 2009 | 11:07 AM
Storms of War's Avatar
Well, that explains why it's doing it on my car. I thought I messed up somewhere when I bolted my console up again
Oh well, Guess it's time for a custom console.
Old Jan 21, 2009 | 11:49 AM
you dont want an aftermarket shifter? have you considered just cutting down the stock stick? im not sure what yourr new stick looks like but maybe if you put a bend in it it will clear everything?
Old Jan 21, 2009 | 09:25 PM
HoLLo's Avatar
Um.. i took my 6" short stick directly from my stock shifter to my new Hurst shifter without any problems.. It's only 2 bolts
Old Jan 21, 2009 | 10:26 PM
Counted Out's Avatar
I'm pretty sure the stock stick is removable. It should work fine.
