burning plug wires!!!!
Old Jan 20, 2009 | 12:13 AM
proace4's Avatar
Default burning plug wires!!!!
ok so i need help bad... I've had the headers on the car for about 4 months now and i have had to replace 4 plug wires. what are you guys doing to make it work and keep it dependable? i have heat shields on two plugs. thanks in advance!
Old Jan 20, 2009 | 12:24 AM
Elliott's94Z's Avatar
Well if you can't zip tie them out of the way your best bet would be to run the "over the top valve cover" style. A lot of guys do this because of your exact issue and because it looks nice!
Old Jan 20, 2009 | 12:27 AM
sepno77's Avatar
taylor over the valve wires sold at thunderracing.com
http://www.thunderracing.com/catalog...vid=4&pcid=104
Old Jan 20, 2009 | 12:32 AM
moderate Z28's Avatar
Just ordered my set of OTVC MSD's from 99blancoss, a member here. Cant wait to get them. They were at a great price too. OTVC is going to be so much better.
Old Jan 20, 2009 | 12:38 AM
1994Z28Lt1's Avatar
the hooker LT's are obviously different from the pacesetters i run but i run the wires on the drivers side in the factory location, on the passenger side you have to get a little creative with zip-ties and what not so you dont burn wires.
i as well have some heat sleeves around the wires on my passenger side, just be patient and make good use of zip ties it can be done
or you could get the over the valve cover wire set from thunder as previously mentioned
Old Jan 20, 2009 | 12:56 AM
ss.slp.ls1's Avatar
I like the OTVC kits, but I am using the stock location right now, but I have Accel heat insulating sleeves on all of the plug wires, so far it works great.
Old Jan 20, 2009 | 01:36 AM
mhayes2344's Avatar
+1 on the taylor OTVC set...works great and looks good too!
Old Jan 20, 2009 | 12:15 PM
proace4's Avatar
Thanks for the responses. Do any of you have some pictures of this set up? Oh and did you just use the 8 mm wires or upgrade?
ss.slp.ls1's Avatar
They look sweet, try a search for pictures, and I'd go with MSD 8.5 wires.
Old Jan 20, 2009 | 12:23 PM
proace4's Avatar
will the mad 8.5 mm wires fit in their set up? Wonder if I can buy just the kit minus wires?
Old Jan 20, 2009 | 12:24 PM
ss.slp.ls1's Avatar
LOL, I sad MSD.
Old Jan 20, 2009 | 12:33 PM
Stroked96Bowtie's Avatar
Originally Posted by ss.slp.ls1
LOL, I sad MSD.
Think he got what you sad
I cant go with the popular vote on this one, I think the over the valve cover looks tacky. If the plugs are ran in the stock location you shouldnt burn any. Take some time to directionally locate the boots and wires going away from the header.
I did have to use one heat sleeve that accel makes on the third cylinder back on the drivers side. Cured the problem though before it burned up a wire (running the msd 8.5s).
Good luck whichever way you go.
Old Jan 20, 2009 | 12:41 PM
ss.slp.ls1's Avatar
Agreed, running any wires in stock locations (tucked nicely) with heat insulating sleeves will work perfectly. I too and using the Accel heat sleeves on all of my wires (Duralast 7mm wires) routed through the stock locations with no problems.
Old Jan 20, 2009 | 02:12 PM
HoLLo's Avatar
I burned about 5 wires after my header install. I eventually got with 99blancoSS to make me a set of MSD 8.5mm wires that would fit with a Made-For-You OTVC kit which I purchased. I should not have that problem ever again
Old Jan 20, 2009 | 02:25 PM
I8ASaleen's Avatar
I used DEI protect-a-boots for 90* boots and zip tied them on, then I ran them away from the headers (I have hooker ceramic coated LT's) and I only had to use a few zip ties. Oh I also picked up some Moroso plug wire seperators at O' Reilly's for cheap and they helped quite a bit keeping them away from the primaries.
Old Jan 20, 2009 | 02:36 PM
AChotrod's Avatar
My MSDs are just zip tied away and no burns yet. Im not a fan of otvc once they get dirty it looks like crap IMO
Old Jan 20, 2009 | 02:49 PM
ss.slp.ls1's Avatar
That's the way an LT1 is supposed to look!
Old Jan 20, 2009 | 03:36 PM
djjab57's Avatar
thanks for the info and link, that is what i need
Old Jan 20, 2009 | 04:27 PM
AChotrod's Avatar
Thanks!! Hope its a 388 stroker by the end of summer!
Old Jan 20, 2009 | 05:30 PM
1redta's Avatar
Default re
too purty to put in your car?
