Oil Pump Spring
Old Jan 20, 2009 | 10:53 PM
ElkySS's Avatar
Default Oil Pump Spring
kinda a dumb question. where is the oil pump spring? i wanna put in a high pressure spring but idk where it is. also does anyone know where to get a high pressure spring?
Old Jan 20, 2009 | 11:13 PM
shbox's Avatar
It's in the oil pump, LOL. You have to remove the bottom plate to change it. You can't miss it.
GM white spring 3848911.
Old Jan 22, 2009 | 02:08 AM
ElkySS's Avatar
just out of curiosity, how high will my oil pressure be with this spring?
Old Jan 22, 2009 | 07:01 AM
shbox's Avatar
~70 psi cold, ~20 hot idle, ~60-70 hot, high RPM, depending on bearing clearances.
