Opti cap removal tool?
Old Jan 21, 2009 | 08:09 PM
I8ASaleen's Avatar
Default Opti cap removal tool?
Alright I'm getting ready to install the timing cover, opti, and waterpump so I need to remove the cap on my new opti and locktite the rotor screw, but I can't remember how to make the tool. I know you have to use one of the torx screws that comes from the tb plate but I can't get it to stay in place and I don't wanna ruin the threads on it.
Old Jan 21, 2009 | 08:41 PM
FASTFATBOY's Avatar
Go buy the correct inverted torx socket, grind the shoulder off it so it will drop down in the hole.
RamAir95TA's Avatar
If you're interested in a socket, use a thin-walled E4 inverted torx.
Old Jan 21, 2009 | 09:37 PM
ThoR294's Avatar
Hammer. Smash it to bits kaldsjlasdjfkasdjkf
Old Jan 21, 2009 | 09:43 PM
myltwon's Avatar
the inverted E4 is a ************ to find, I couldn't at any parts store so had to have a local shop do the swap for me
go to LT1engine.com for the info on how to make it
you just need the throttle body plate screw, a 1 nut and 1 wingnut
Old Jan 21, 2009 | 09:56 PM
shbox's Avatar
Or take a throttle plate bolt to the hardware store, get another longer bolt with the same size E4 torx head, jam nut and wingnut and make your tool for a buck or two.
Old Jan 21, 2009 | 10:01 PM
myltwon's Avatar
^better idea, the tb screws are very short and fragile
Old Jan 21, 2009 | 10:15 PM
I8ASaleen's Avatar
Pssssh, used some electrical tape, an old tb screw and a pair of vice-grips reeeeeeeal tight.
Old Jan 21, 2009 | 10:39 PM
I8ASaleen's Avatar
What the hell size are the rotor screws??? GM really doesn't want you to mess with this distributor...
Old Jan 22, 2009 | 07:53 AM
leadfoot4's Avatar
SK makes one, and you don't have to grind it. It's number 42604.
Old Jan 22, 2009 | 07:58 AM
leadfoot4's Avatar
The rotor screws are 6-32, Torx headed screws. To install/remove those screws, I have one of those "bits" that's 1/4" square, and fits into a "screwdriver handled" tool. The "bit" is stamped "T8"
Old Mar 2, 2009 | 02:26 AM
gatorhead's Avatar
I purchased my E4 from Pep Boys just in case anyone is looking for one, they were the ONLY ones who had it and I checked everywhere local to me.
Old Mar 2, 2009 | 06:25 AM
xx_ED_xx's Avatar
I was wondering that as well. My smallest socket is still too big to fit it
Old Mar 2, 2009 | 06:49 AM
creepingdeath94's Avatar
I would think NAPA or a tool truck would have one...like Snap-On...but they would be pretty expensive if you are only doing it once. I have a couple different sets of various torx bits and I purchased them all from the Snap-On truck or Sears possibly.
Old Mar 2, 2009 | 09:40 AM
ss.slp.ls1's Avatar
Yeah, Autozone cares them too. It has a yellow label and clearly says E4 on it.
Old Mar 28, 2011 | 03:02 PM
GR33N GoblinM6's Avatar
here ya go..
http://www.lt1engine.com/tech/085-opti-cap-rotor-tool/
Old Mar 28, 2011 | 04:05 PM
linkziz's Avatar
http://buy1.snapon.com/catalog/item....e=&dir=catalog
Thats what i have. I mainly use it for GM steering columns. It does have more uses then just for a LT1.
Old Mar 29, 2011 | 09:10 AM
glassjaw1704's Avatar
Inverted E4 and T9 for the rotor.
Old Mar 29, 2011 | 12:03 PM
LigHtEmUp01's Avatar
get an e4 socket from autozone for 3 bucks
Old Mar 29, 2011 | 01:26 PM
myltwon's Avatar
Originally Posted by GR33N GoblinM6
already posted in here
