Solid Roller 396 Dyno Guesses
Old Jan 30, 2009 | 06:15 PM
  #41
FASTFATBOY's Avatar
Originally Posted by flyinZ
David, what if you make the same amount of hp, as you do tq? Just a thought.
To the PWN3DR, if you bought the car that way, I would make sure you could verify all the performance parts, that the seller told you about..It never hurts to double check, something like that.
Its USUALLY an indication of a combination thats not efficient. There are many reasons. The manual trans or a locked converter is the only way to really tell on a chassis dyno.
Usually due to a cam thats too small, wrong cam(lack of cylinder pressure) or heads/intake that are too small for a certain cubic inch engine. This only applies to normally aspirated combos in general but if you look at dyno sheets of a real efficient combo, NA or not it will always make more HP than TQ. Past 5250 rpm of course.
If my car had a six speed it would probably make 520/530 rwhp and 460 tq, thats just a guess.
The only dyno I have it makes locked 463/431(peaks) but that was with 2 wounded pistons, now it prolly makes 475/440 locked.
Old Jan 30, 2009 | 06:22 PM
  #42
engineermike's Avatar
FatBoy, those are impressive rwhp numbers through an auto NA. What's in the motor?
Old Jan 30, 2009 | 06:31 PM
  #43
FASTFATBOY's Avatar
Oil, crank, rods, pistons, oil pump...ya know. That kinda stuff LMAO
Old Jan 30, 2009 | 07:00 PM
  #44
96lt1m6's Avatar
the oil is covert!
Old Jan 30, 2009 | 10:53 PM
  #45
OutlawZ's Avatar
Yeah fatboy is definitely on the right track..... a good efficient motor will always make more hp.... my car on motor made 485 RWHP thru a TH400, big 4000 stall.....
The swap from a T56 to a TH400 with no other changes was about 50hp lost from the rear wheels... i had dynoed 422ish with a T56 with my old 355..... changed nothing but the tranny and car had 375 RWHP.... but car was much faster in the 1/4....
So an NA LT1 like mine or fatboy's will make 525ish RWHP with a manual.....
Old Jan 31, 2009 | 09:10 AM
  #46
Tony Shepherd's Avatar
Jason I thought you put down more than that on motor? Mine made 522rwhp N/A thru a TH400, 9", and 4400 stall..........I thought you made about the same?
Old Jan 31, 2009 | 08:32 PM
  #47
OutlawZ's Avatar
original pump gas #'s.... I kept my race gas tune #'s on the low low cause of some races i had lined up........ not a secret anymore tho... Made 515 NA with 110 octane race gas.... My cam is a bit smaller than your IIRC.... 248/260 to your 260+ no???? My cam is lazy on motor but rips on spray.... 114.5 lobe sep....
Old Jan 31, 2009 | 09:15 PM
  #48
Oh I see. I thought I remember we where close in n/a power. Mine was dynoed on 93 octane pumpgas n/a but 116 octane on the juice.
Old Feb 2, 2009 | 11:10 AM
  #49
OutlawZ's Avatar
hmmmmm... yeah the highest we have here in california is 91 octane oxygenated **** gas.... I wasn't gonna take that chance with 12:1 compression so we turned the timing down and just made some test pulls to make sure everything was on the up and up... we saved the real dyno for the race gas.....
i woulda blown my **** up on 91 octane pump gas..... it's horrible gas out here cuz of all the hippies...
Old Feb 3, 2009 | 10:28 PM
  #50
daves94formula's Avatar
http://s622.photobucket.com/albums/t...t=DSC01940.jpg
heres the cam card guys!
Old Feb 4, 2009 | 10:09 PM
  #51
SS RRR's Avatar
Village Troll
That cam is pretty close to mine. Just has a little less lift and a tad more duration. I would imagine it will peak around 7000 to 7500rpm.
Good luck
Old Feb 4, 2009 | 10:22 PM
  #52
thanks SS. so what did you "officially" put down on the rollers if you dont mind me asking
Old Feb 5, 2009 | 12:05 AM
  #53
SS RRR's Avatar
Village Troll
Mustang dyno it put down 430rwhp at 6800rpm and 390ftlbs of torque w/ a cutout open just before the axle. Not sure what that equates to in Dynojet language. From what I've been told the dyno I use reads lower compared to the Dynojets around town. Allegedly it has varied up to 30hp on others who've compared so, whatever.
I wouldn't use my engine as a reference since the heads I am using are ported LT4 castings that were designed to run in a 383 with the LPE 211/219 cam. They do alright for what they are, but I'm confident with a 220cc casting I'd see more power.
