i need help with wiring
anyone have any why its getting so hot or what its related too?
i tried to pull the codes and all it seemed to do was turn on the air pump.
Check every inch of the wiring for insulation damage and contact to ground. If you have melting insulation, you are going to have to replace the wire, anyway.
So i checked the fans they work fine.
Is that brown wire a signal wire to the relay in the fuse box? i dont under stand if that brown wire is coming/going from the relay or the fans or what not.
It says on there #6 10a thats the fuse that is blowing. so its not that brown wire. now I have to find what that brown wire (thats heating up) does. and why its now fan related. This probably ties into my CEL also. ( if there is a short)
looks like im going to have to pull off most my front end to access that wiring loom it seems to run from the pcm to the fuse box.
Does it blow the fuse with the fans disconnected? I read that you said the brown wire heats up no matter what, which makes sense because it's a hot wire as long as the car is on so it doesn't matter if your fans are connected or not. Does it blow the fuse without the A/C on or only when you hit the A/C ****?
Try chasing the wire and jumping it with some heavier gage wire and see if it still heats up? Something is shorting out, but at least you can bandaid it with heavier wire hopefully.
I guess just trace it and see what you find. That f pin (brown wire) is power coming from the #6 (fan )fuse. i just have to figure out where that wire is going (possibly not into the pcm maybe other options).
Do you have a 2 or 3 fan relay system? 94s could have either.
Fuse 6 feeds:
O2 sensors
fan relays
reverse lock out
skip shift solenoid
EVAP canister purge valve solenoid
EGR solenoid
Your sig does not say headers, but the most common trouble is a burned O2 wire.
It's important to let people know of your mods. It can save time and effort.
