Ignition question
Old Jan 22, 2009 | 03:08 PM
nightrunnerz28's Avatar
Default Ignition question
Hay guys im new here so plz take it easy on me. Im building a carbed LT1. i no i have to use a old style distributor that sits in the back of the motor. Now heres my question were do i need to cut on the car. and what else needs done to make this set up work?
Old Jan 23, 2009 | 06:49 AM
leadfoot4's Avatar
Were you able to find an intake manifold that will work on the LT-1 heads? If so, you'll probably have to cut up the cowling of the car, in order to get a regular distributor in back....watch out for the windshield wiper assembly.
Old Jan 23, 2009 | 07:48 AM
ya im using the carbed manifold from GM performance thats made for the lt1 i just have to drill out the spot for the distributor. if i have to cut the cowling on the car then i will. the next problem is i dont now what to do with the opti. Im not putting the rotor back on the opti but i have to put the cap on and its going to look like crap.
Old Jan 23, 2009 | 10:37 AM
ss.slp.ls1's Avatar
You can buy an aluminum plate that blocks off the hole, it bolts up to the timing cover using the three bolts that the opti used. I don't know what it's called or where to get it though.
Old Jan 23, 2009 | 06:41 PM
leadfoot4's Avatar
Good call, I forgot about it....I seem to remember seeing it in the GMPP catalog.
Edit....
I was just out in the garage this AM, and my GMPP catalog caught my eye as I was heading back in the house...The p/n for the "front cover/plug" is 12367600
