brake booster/ master cyl?
Old Jan 22, 2009 | 03:41 PM
nik1703's Avatar
Default brake booster/ master cyl?
Is there any way to determine whether my braking problem is the master cyl or the brake booster? any kind of trouble shooting? without replacing both, haha. I am a bit poor, so.
Old Jan 22, 2009 | 04:47 PM
FlamingChicken's Avatar
i would assume if those are the parts you suspect the master would cause a soft pedal and the booster a hard pedal. you can pull the vacuum line off the booster after you shut the car off. if it releases air then the booster is at least somewhat working.
Old Jan 22, 2009 | 05:01 PM
nik1703's Avatar
the pedal isnt hard or soft, its normal... just the braking power isnt there...
Old Jan 22, 2009 | 05:06 PM
James Montigny's Avatar
What do the brake pads look like?
Old Jan 22, 2009 | 05:08 PM
nighthawk15's Avatar
+1
generally if there's a problem with the system itself you will feel it in the pedal somehow. For example mine got a fluid leak and the pedal would travel almost to the floor without braking power until the very end.
Old Jan 22, 2009 | 05:23 PM
nik1703's Avatar
the brake pads are good... i checked them when i took the wheels off to bleed the system last week thinking that the bleed would fix the problem. I dont have any fluid leaks though.. i am totally stumped!!
