What kind of gaskets for ported heads?
ported heads and intake? All I see is stock sized Felpro
gaskets
Won't the gaskets interfere with the flow of theheads and ported intake?
For intake, I always used the GM/Fel-Pro gasket. If you're using these and still getting interference, it sounds like the port has been enlarged too much. I guess you haven't hit a coolant passage yet?
FWIW, I now use Earl's Pressure Master gaskets. They've got removable inserts which came in very handy when I switch from stock heads (d-port) to my larger AFRs(square port).
or is that a stupid idea. Will that cause header
leaks? I just don't understand why there no
larger sized gaskets made. No problem finding
them for mustangs lol
