Out of the box heads
Old Jan 26, 2009 | 07:35 PM
The Batman's Avatar
well i have been looking at the afr 210's quite a bit today, I like that i dont have to run any special parts to make them work since all my normal lt1 stuff will work. Im really interested in the whole off the shelf idea since i can still startup my car and drive it until i source all the parts for my build---->almost no down time is a good thing
Old Jan 26, 2009 | 07:37 PM
James Montigny's Avatar
Originally Posted by 96capricemgr
The Darts have been tested in as cast form, worked as well as slightly worked LT1 iron heads.
And ported; 300-330cfm, depending on the application.
VS the 270-290 max you see from stock castings.
Dart now offers 180, 200 and 210cc versions off-the-shelf.
They have a very nice valve job and a well-designed chamber.
I wish they'd find a way to move those pushrods and eliminate the bottleneck.
Old Jan 27, 2009 | 08:54 AM
BLWNLT1_T/A's Avatar
where do you find the dart heads? I would like to look into those. Also what cc chamber do they have. Looking to lower compression with my setup.
Old Jan 27, 2009 | 10:04 AM
myltwon's Avatar
dart heads are 58cc
Old Jan 27, 2009 | 10:20 AM
Advanced Induction's Avatar
Smile
Last Feb. we had two different engines from Ellwein on the dyno. One was a 12.X:1 383 with as-cast dart 190cc heads & the other had a little less compression and more cam, but had our 215cc cnc'd TFS head. Both had the same piston & ring package. There was a 9Xhp/25% output difference between the two engines on 93 octane. While some of that is attributable to the cam difference, it would still only be ~30hp.
If you must purchase heads now, most any of them (darts, tfs, afrs) will be an improvement over stock. Our cnc'd 200cc head with a HR is something that has a proven history of achieving what you have asked for & would be our recommendation for most 350-355cid guys. Something like the 21deg TFS' we're working with would be nice, but they are not available yet. Perhaps late Feb - mid March.
420-450rwhp is not asking for the world, but you might want to look at the other side of gaining peak numbers. That is, what are you going to give up if you use a 220cc head to see that peak number vs. a 200cc head. There will be a discernable performance difference, both SOTP and quantifiable on a dyno or at the track. On line there are a great many "hoping" for numbers. Fortunately, this is an industry where hope isn't necessary. If you spend your money wisely and emulate those who have already achieved your goals you should also manage to get there. Cylinder head work is primarily machine time and hours. No matter how much you hope you will never receive what you don't pay for . If you can wait and spend money on something closer to ideal and/or higher quality for your application then you will have saved in the long-term.
Old Jan 27, 2009 | 10:32 AM
AChotrod's Avatar
Im more than happy with my stock ported heads! My numbers are what you want out of your car. Look at Larry's(LS1 Speed) car hes running 10s NA on LEs stock ported heads.
Cant go wrong with LE or AI.
Old Jan 27, 2009 | 10:53 AM
Z-RATED94's Avatar
I could be wrong, but Larry is running a LE cam, not LE heads. They are ported stockers though. Please correct me if I'm wrong.
And by the way, my heads will be going back to Lloyd for some more work, and SpeedInc. will be doing the work, as usual. Damn, I love that shop.
Old Jan 27, 2009 | 03:49 PM
http://www.dartheads.com/products/cy...ro1-heads.html
You can order direct from Dart or from Summitracing. (I got mine from
Summit, along with the valavetrain components Lloyd suggested, and installed for me)
As-cast chambers are 58cc, I had mine milled to 56cc to acheive the desired geometry.
Old Jan 27, 2009 | 03:56 PM
AChotrod's Avatar
LOL! Ya your right!! Dont know what I was thinking. His are stock ported heads and custom LE cam.
Ya my car should be back at Speedinc on fri again for some tuning and dyno time Lets see where the TDs put me!!!
Old Jan 27, 2009 | 05:28 PM
Paul Bell's Avatar
That's MISTER MODERATOR
Always a qualified and well thought answer from the good fellas at Advanced Induction. Give them a call and they’ll guide you in the best direction.
Old Jan 31, 2009 | 11:45 PM
sixpack_2_go's Avatar
trickflow "as cast" heads. if you want to go bigger later on TEA will port your as cast heads for 600 bucks
