Out of the box heads
Old Jan 25, 2009 | 08:47 PM
The Batman's Avatar
Default Out of the box heads
Well tax time has come and heads are on my list. Ive been drooling over sending the heads off my 93 to Lloyd Elliott for his LE2 package with LE3 cam but have been pondering just getting the LE3 heads as well or the AI 200cc package. I was just talking it over with my old man, and searching this forum like crazy for a while now. Cant seem to find the info im looking for.
Anyways, is there any out of the box/off the shelf heads built by trick flow or AFR or someone else that perform as well as these ported stockers? Im shooting for 420-450rwhp thru an m6. but i would like to have a head that in a few years i could send to one of these guys to port even more. Kinda just want a head that i can grow with in the future. Ive looked around for some time now and cant really get a direct answer...thanks
Old Jan 25, 2009 | 08:48 PM
The Batman's Avatar
oh, i know that the ported stockers would be just fine for now...but in the future i want to expand
Old Jan 25, 2009 | 08:54 PM
kierstyn's Avatar
You can look at my thread a few posts down to get some answers!
Old Jan 25, 2009 | 09:05 PM
joelster's Avatar
AFR 210 or 227 out of the box will deliver that. You can get them cheaper than what they say on their website also.
http://www.airflowresearch.com/sbclt.php
Old Jan 25, 2009 | 09:15 PM
The Batman's Avatar
i had thought about the 227's but i heard that they can be diffucult because they reposition the pushrods or something. I wasnt too sure.
Old Jan 25, 2009 | 09:20 PM
Taubr Unit's Avatar
Iv been seeing a lot about the AI stuff and it looks to be that there REALLY making a impact on the lt1 world. Not that they wernt before just seems to be a lot of AI stuff popping up lately on here, just going off that.
Old Jan 25, 2009 | 09:23 PM
The Batman's Avatar
and wouldnt i need an lt4 manifold to run either of those heads?
joelster's Avatar
You need to run a few special parts. A friend of mine runs them with a stud girdle which was $200 or so. It doesn't see too much street time. If you run them on the street you should get offset shaft mount rockers which are very pricey ( $800+), then of course offset lifters which are $500+. I heard you could run them on the street with just the girdle but the intake rocker would be cocked a little and may require adjustment after a while. My friend doesn't have any issues that I know of though, although it doesn't see a lot of street use.
Oh, he runs 9.60's btw in a 3600lb IROC.
Old Jan 25, 2009 | 09:25 PM
The Batman's Avatar
oh definetly...i know that ported stockers would be awesome now, but in a year or two i would want to upgrade from that and not have to purchase new heads and then have those ported
Old Jan 25, 2009 | 09:26 PM
The Batman's Avatar
is that just with the 227's or do the 210's work the same way?
Old Jan 25, 2009 | 09:32 PM
joelster's Avatar
The 210cc heads are available in either standard or spread port exhaust. Straight plug versions and down nozzle provisions are special order only. No special parts are required
Old Jan 25, 2009 | 09:50 PM
The Batman's Avatar
yeah i just read that, so i could use my lt1 intake and standard roller rockers if i understand correctly. Ive found them for $2000 shipped so far. anyone sell them cheaper?
Old Jan 25, 2009 | 10:28 PM
myltwon's Avatar
dart makes a pretty good cheap head from what I hear
Old Jan 25, 2009 | 11:30 PM
LSWHO's Avatar
They flow only slightly better than LE1s.
Old Jan 26, 2009 | 08:25 AM
The Batman's Avatar
^^^yeah...im looking for a bit more performance than the LE1 ranked heads
Old Jan 26, 2009 | 09:30 AM
96capricemgr's Avatar
The Darts have been tested in as cast form, worked as well as slightly worked LT1 iron heads.
The ported stockers are capable of more than most will ever ask, so how much more do you really want? Solidly capable of 10s NA in a true street car.
Old Jan 26, 2009 | 10:19 AM
BLWNLT1_T/A's Avatar
how would tfs 62cc heads compare...
Old Jan 26, 2009 | 10:48 AM
nichols92's Avatar
Check with T.E.A. but I would run AFR heads for sure.
Are you planning on 450RWHP with heads/cam?
Old Jan 26, 2009 | 03:33 PM
The Batman's Avatar
yea, will be a 355ci
Old Jan 26, 2009 | 04:33 PM
Racin96ss's Avatar
If I was buying heads right now I would look into the Trick Flow 21* by AI.
