Am I smokin crack with this Corvette CAI?
Fuel rails I took apart as possible, and powdercoated them up, then put new O rings on and thats it.... I almost did it the reverse black intake with red rails, I often see people with the black intake and polished rails which looks good too but I have a red car and no underhood bling so this is it, I'm gonna hand paint the lines on top of the intake black also....
Where can you get the rubber peices that everyone is using between the TB and the mass airflow sensor? Home Depo? The photo of the black car with the J bend pipe looks like it was professional. I would think that routing the intake to down there in front of the radiator and stuff would be a big improvement over where the other aftermarket filter kits pick up down behind the turn signal, especially at highway or track speeds.
I have a Fernco elbow on the MAF that runs to a 6" peice of PVC pipe down through the radiator support with a K&N filter like the on in the pics. The only things needed to make it fit is cut the plastic shroud, and clearance the radiatior support where the elbow will be. Its just so it doesnt tear up the rubber, and should give you more space to work with when you 1st install everything. Here's some pics of whats on my car, along with a similar setup for a vette that might fit with some modifications.
![](http://www.drillspot.com/pimages/2578/257853_300.jpg)
![](http://www.platinummotorcar.com/RAPTOR1.jpg)
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#33
Thanks 4 that, I just got smoothie valve covers and I have my water pump apart to do a EWP conversion I'm up in the air if they should be black/red also or if I should do something else like a silver color... I did the timing cover in a alum colored silver a while ago which looks good but does get dingy lookin.... I'll put up some pics in a bit....
