temp guage question
Old Jan 28, 2009 | 09:22 AM
mistamista's Avatar
Default temp guage question
i got a 96 t/a and my factory temp guage quit working so i went and bought a autometer electric temp guage will it still work with the factory guage not working and where do i hook it up to or should i have bought a mechanical one thanks
Old Jan 28, 2009 | 09:24 AM
ss.slp.ls1's Avatar
The temp gauge likely quit working because the temperature sensor on the driver's side head went bad. I would just replace the sensor. It should be accurate enough.
Old Jan 28, 2009 | 07:51 PM
mistamista's Avatar
so i replaced the temp sensor the one in the front by the water pump still nothing any other suggestions thanks
Old Jan 28, 2009 | 08:04 PM
RamAir95TA's Avatar
You need to replace the one in the driver side cylinder head. That is where the dash receives it's reading. The one in the pump is for the PCM.
Old Jan 28, 2009 | 08:28 PM
Formula350's Avatar
I suggest reading what people say more closely, or multiple times, before you start chucking parts at the car
I just scanned the first guy's reply and saw he said "driver's side head". But hey, at least you know your PCM is getting the car's temperature now
Old Jan 28, 2009 | 08:47 PM
mistamista's Avatar
man i just noticed that i should have read that over a little better
Old Jan 30, 2009 | 01:11 PM
mistamista's Avatar
so i changed out both sensors and guage still just lays down could it be something in the dash or the wire coming off the sensor
Old Jan 30, 2009 | 01:18 PM
ss.slp.ls1's Avatar
Sounds like a wiring problem. I would test the voltage at the pigtail. Are you getting a code?
Old Jan 30, 2009 | 01:32 PM
mistamista's Avatar
no codes with the after market guage can i just put it on to the wire that is on either sensor you think that will work
Old Jan 30, 2009 | 01:39 PM
ss.slp.ls1's Avatar
The temp sensor in the WP has to stay there and be connected, it's used by the PCM. If it will work with the wires on the temp sensor on the head, then use it, but I have no idea if it will. I would still try to find out why your gauge isn't working. I would be concerned that the wires are damaged/burned and if so, maybe others are too or will be. If the pigtail reads the appropriate voltage, then it's likely a problem with the stock gauge, not a big deal. Then you can just run your aftermarket temp gauge (once you know how to hook it up) and be fine.
Old Jan 30, 2009 | 01:40 PM
mistamista's Avatar
sounds like a head ache
Old Jan 31, 2009 | 12:54 PM
Black94Z28's Avatar
my gauge was busted on mine (read that it was overheating all the time) so i just went and bought a mechanical one at autozone and it works fine. plugged it into the drivers side head and ran the line into the interior. I have the gauge mounted on the piller. Easy to do, $30 and maybe an hour?
