lt1 58mm intake porting ??
With that said its pretty stupid to open them up with the intake on the car considering how easy it is to pull it off. All it takes is a couple shavings to get past the rags to trash your shortblock, and I really don't think saving 30 minutes of work is worth the risk. Not to mention you can do a much better job with it off the car.
Hell I had an intake ported a couple years ago by a popular head porter and it was still full of aluminum shavings. If I didn't check it I wouldn't still be running a stock shortblock.
i just took my time soaked the rags with oil taped up everything plugged the inside holes with ear plugs and went to town wit the dremel it took a little longer then i expected but it wasnt bad
Wonder why no one does siamese intake 'runners' on the LT1 manifold like people did on the TPI base :\ Meh dumb idea, just thinking aloud lol
If you do decide to port the intake please take it off or just trash a motor for 20 mins worth of work.
the floor of the intake is acually lower than the heads so gasket matching just makes the angle too miuch.
read the bfranker page and it tells about the 58mm on a stock motor. it does help
I got this information from Ed Wright. He had dyno tested this on his 383 and stock cube motors. I trust what he says and was tring to help others.
Pics!
I assume you used a dremel or air bit?
