Need a diagnosis.
I'd suggest, if you can get your hands on an ICM (from pretty much any 90+ GM v8 I'd think), be it from a friend's vehicle or another of yours, and test it with your car while cold and after you've driven to the point that it'd restart hard, that it could help at least eliminate something.
Just thought of it, that it could be intake air temp or coolant temp sender (in the water pump for the computer. Anyone else see that as a possibility?
Well i finally got the bird running. I went to the local junkyard and picked up a Coil with the ICM, swapped it out and the car fired right up. So the problem was the Coil or ICM, but either way...problem solved!!!
it would be nice to narrow this down so you could put on a new part and not worry about it failing again. how about changing each 1 of those out by itself and seeing what happens....
