v6 to v8 swap
ok now is it plug and play for the inside for the car from the v6 or i got to change in the inside car from 95 to 97 and thats about im worried about the inside of the car wiring now
Your 97 is OBD II wich will be a little different from the 95 OBD I harness but if you move wires around on the connectors you can make it work. Little more work this method.
Try this link it will help you a lot.
http://www.tacreationsusa.com/3_4_3_8_v6_to_lt1.htm
is it all that bad of a deal to switch the connections over?
only harness i swapped was the engine harness, i just had to get the pin outs of the 3 plugs in the passenger kick panel for the 96 and 93 and just swap the wires around so they will all match up. because the plugs will be the same, just some of the wires will be in different places. i also had to change out the plug and match up the wires to the one on top of the passenger wheel well because i didnt swap out the front harness. but you dont have to worry if you already swapped the front harness
If you swap the V8 front end harness to the V6 car, that is plug and play, and in turn makes the engine harness plug and play.
If you use the V6 instrument cluster, the tach will read high. Switch the the V8 cluster and all is good.
