header install question????
i have done an Lt1 and an Ls1 in the same day start to finish. that was 8am to 6pm almost non-stop....
the best way to save time is having all needed tools near you,look at the parts being removed and installed gather your tools,undo your battery first the y-pipe,starter,pull the alternator off and out of the way then remove the manifolds,if you are reusing the egr air tube attatch this while the header is loose do not tighten it yet!wait till the job is close to being done.....
obviously there is more but you should have a good idea.
