Few cylinder head questions
I pulled my passenger side head to get a broken exhaust manifold bolt machined. Now that i am about to put the head back on i have a few questions....
1)How do I clean the head safely to remove metal shavings from the machince shop?
2)Do i have to set the valve lashing? what exactly is that? i only pulled the head bolts and rr bolts off, didnt mess with the springs or anything else
3)Do i have to get a new head gasket?
btw i didnt notice coolant in cylinder 8when i pulled the head, but now there is a very small amount in it, should i be worried? car ran great before i started tearing down. also alot of coolant came out from the bolt holes when pulling the head, maybe its from that?
thanks guys for your help!
here is a pic![](http://img167.imageshack.us/img167/1696/p1000530vs3.jpg)
here is a pic
![](http://img167.imageshack.us/img167/p1000530vs3.jpg/1/w640.png)
Those pistons look pretty good actually. I would just get some simple green and use a rag to wipe down the cylinders and piston heads. Maybe wipe a WD40 soaked rag on the cylinder walls afterwards.
You MUST use a new head gasket.
You MUST set the valve lash - http://shbox.com/1/4th_gen_tech2.html#adjust_valves
You forgot step one...draining the block before you pulled the head. That's why you got coolant everywhere. I would change your oil, other than that, you should be fine.
Good luck with the rest.
I agree with this guy Mike.
A WD-40 rag will be great, and make sure to get all the coolant out of there. Coolant doesn't compress.
New gasket is a must.
Change you're oil, because you don't want milky oil running through your motor. Your cam will thank you.
Valve lashing is pretty tough, and if worse comes to worse, I can hook you up with someone to do it for you. Tom, Dave, etc.
also to clean up the head go get a sanding block and about 500 gritt sandpaper and sand in a even circular motion! You don't have to get it perfect, but get the majority of the gasket material off!
