LE's 223/230 @ 112
Man I know What your talking about. I've wanted to do a cam swap since I got my car when I was 16. My dad always refused to help so now that Im 19 and have more mechanical skill Im going for it. Im so stoked to do it.
is there anyone else out there running this cam ? i wanna hear some power numbers with supporting mods to psych me up even more.
Ive been talking to lloyd the past couple days, he said with this cam le2 heads, ported intake, 58mm tb, 1 3/4inch lts no cats, catback exhaust... pretty much all the supporting mods an m6 car should be close to 400rwhp.
It should if not more. 1 7/8 headers would be better to run to achieve that goal along with pretty much every bolt on possible. Either way it's gonna have a butt load of torque through-out the entire power band. Run a electric cut out and it should be good or another 8-15 more at the rear.
i did the lt4 knock module along time ago after i did my mac mids. it was cheap and really easy to install. im going to keep my heads stock except for milling them down abit. 400 hp sounds like a great number with that cam when i do heads and LPP's new long tubes! i might need a new bottom end after that tho that and a rear end haha lloyd said that with the mods i have and a good tune ill see 330-340 and id be More then happy with that. def be enough to handle my friends 335i
#32
i know there alot better buck for buck. but when i did them i didnt want to have to lift the engine and whatnot. i didnt have the time nor help. but when i send my heads out i wont have to worry about lifting my engine up i cant wait to see how the new ones are going to be! my pennies are all being saved for those bad boys! ohh i cant wait for summer!!!!!
#37
I got it! along with all parts id need for the swap. my head gaskets are on the way. is anyone running this cam ? how much do you guys like it ? the second i have a place to do it im going to start tearing into it like an animal. this is my first LT cam tho so if there are any tips that would help me out id really appreciate it thanks guys!
