383 lt1 hp?
Old Feb 10, 2009 | 08:39 AM
James Montigny's Avatar
Originally Posted by RamAir95TA
It's not an unknown reason. They just don't know any better. That's why they come to the forums and ask for advice.
I call it "Monkey-see, Monkey-do syndrome" 4 is bigger than 1 ... must mean it's good. Saw it in the Summit catalog
I was just talking to someone at a machine shop the other day who had just put one in.
Old Feb 10, 2009 | 09:24 AM
Greenfire's Avatar
No LT4 hot cam in my 383. I'm not sure why people still use the LT4 hot cam when there is better stuff out there...this girl didn't go that route. I had a few friends help me with this build and did some research of my own. Try to think about what you want out of the car and set a goal for it.
Def go with a bigger cam...mines a 383 LT4 and I def went with a bigger custom cam from Bret @ Bauer Racing. Great customer service!
Cam specs: 236/248 570/571 108.5
Car sounds like a beast..no numbers yet as I have a few things to tie up on the car but should be good for over 400 rwhp.
Old Feb 10, 2009 | 09:25 AM
explicit.muscle's Avatar
well, you all will be happy to know, I took all of your advise(mainly ss.slp.ls1 and 96capricemgr, for making me feel like a dumbass for even thinking about using an lt4 hot cam) i am now getting the cc503. More power can't hurt, right??????
Old Feb 10, 2009 | 09:26 AM
ss.slp.ls1's Avatar
Nice to see you did your homework. I like those specs, should be a monster.
Old Feb 10, 2009 | 10:28 AM
RamAir95TA's Avatar
Not to take away from 96 or slp, but you need some supplemental information...
Where in this thread does anyone recommend the CC503 for a 383? That cam is widely reknown as being the best cam for stock heads (XE lobes, 224/230, .502/.510 112 LSA). If you're using ported LT4s on a 383, the 503 is still small considering what you COULD run. You need more duration and more lift to take advantage of the cubes and stroke, plain and simple, if you're mentality is "more power can't hurt."
You might want to take mine and OutlawZ's additional advice with the XE236/242 if you don't want a custom grind (even still, a custom grind is the best case scenario). It's an off-the-shelf profile that is also proven in bigger displacement motors.
Like I mentioned, there's a short video clip of it in my signature if you're interested.
Old Feb 10, 2009 | 10:38 AM
ss.slp.ls1's Avatar
Originally Posted by ss.slp.ls1
Custom grind.
During your build, you would give either Lloyd Elliot or Advanced Induction a call and explain to them your setup in detail and they will spec out a cam for you and grind you one.
Well if you don't know anything about it, I'd say run something like...
23x/23x .575/.575 108 but that is just a complete shot in the dark.
Take his advice.
I didn't see it either, but I'm sure it's there.
I did see this one:
http://www.compperformancegroupstore...Code=LTCAMSXFI
242/248 .584/.579 113.
Did you even read my posts???
Now where did I mention to use the CC503...that is what I am using in my cam-only 350.
At first I told him to get a custom grind. I told him min would be a 23x/23x. I told him to go big and take Outlaw's advice with the 236/242. I even linked him a bigger cam, a 242/248.
Old Feb 10, 2009 | 10:45 AM
kinglt-1's Avatar
Im running a 230/236 custom grind in my 383 and I would not go smaller! A 236/242 would be a nice choice, but thats is high as I would go for a street car.
Old Feb 10, 2009 | 11:25 AM
i went with that cam because the heads are lt1, bored out to lt4 specs, and i wanted to play it safe. Better heads in the future......cant afford them right now.
Old Feb 10, 2009 | 11:29 AM
ss.slp.ls1's Avatar
That's what sucks about not planing out your build wisely, taking your budget into your account. Odd are you could have build a 355 with a better top end that will out run your 383 when you finish it.
Old Feb 10, 2009 | 11:36 AM
well, the only reason im getting this engine is my buddy bought it, and now he needs cash. im paying 1200 for the engine(just went up 200 for the cam swap), and it has never been used. I hardly ever race, so I was happy with stock.
This engine came up for sale, and i said screw it!!! ill buy it!!!
So i think im doing pretty good for only 1200 bucks!!!
Old Feb 10, 2009 | 11:50 AM
ss.slp.ls1's Avatar
I agree. Didn't know the whole circumstances.
I don't know what would be your best bet for a cam choice in a 383 with stock heads. I would still probably give Lloyd a call and see what he says.
Old Feb 10, 2009 | 12:03 PM
  #32
RamAir95TA's Avatar
What are "LT1 heads bored out to LT4 specs?" The only difference is that LT4 heads have .100" raised runners and flow mildly better. Do you mean they are ported? And if so, by who?
Old Feb 10, 2009 | 01:33 PM
  #33
myltwon's Avatar
with unknown quality port work on heads I'd stick with a cam that works great with stock heads rather than one that relies on well ported heads
Old Feb 10, 2009 | 01:39 PM
  #34
ss.slp.ls1's Avatar
Good point, he said he was going with a CC503, so I guess he's good.
Old Feb 10, 2009 | 02:23 PM
  #35
kinglt-1's Avatar
I would still think a 230/236 grind would still work well on a 383 w/ stock heads. The bigger cubes help tame the cam down. It would be like running a 220/226(roughly) on a 350. I think Power should peak at 6000-6200 rpm.
Old Feb 10, 2009 | 02:25 PM
  #36
That is exactally why I chose the cc503. I have no idea about the quality of the heads, and I wanted to play it safe. Later on when I get some better heads, i'll let you guys argue over which cam I should use then
  #37
ss.slp.ls1's Avatar
Yeah, an Ai 230/236 cam would probably be good. Hell, I'd run a CC306 if I was him.
Old Feb 11, 2009 | 01:38 AM
  #38
AnthonyConstant's Avatar
I call BS on this whole topic.....a grand? But know nothing about nothing.
Old Feb 11, 2009 | 03:11 AM
  #39
bombebomb's Avatar
I am running a slightly larger cam on a 383 231/239 with untouched stock heads. It seems to have quite a bit of power. Future plans are to port the heads however, so this may be completely unimportant to the op.
