Can I get low 12's?
Old 02-10-2009, 08:17 PM
moderate Z28's Avatar
Default Can I get low 12's?
What do you guys think I can run with my setup? This is on a 93 Trans Am auto.
LT4 hotcam, 1.6 comp-pro mag full roller rockers, mac mids, cutout, 3.73 gears, MSD 8.5 wires, tune by Madtuner.com, K&N CAI, 52 MM throttle body, drag radials, !EGR, !EVAC, !AIR, every single bolt on available for the lt1 minus suspension, and the serpentine belt removed for a few extra ponies? Stock stall converter though. Also, I only weigh 160 lol.
Old 02-10-2009, 08:29 PM
Black94Z28's Avatar
Id say get a stall and u should be there if not faster!
Old 02-10-2009, 08:35 PM
Are very high 11's possible?
Old 02-10-2009, 08:48 PM
SHDY 5.7's Avatar
I know of a z that has the identical set up with the exceptions of a stall and long tubes. It ran 12.40 with a madtuner tune. I also think he had all his accessories.
Old 02-10-2009, 10:36 PM
paul12001's Avatar
im trying to hit 11s myself with my LT1
Old 02-11-2009, 12:52 AM
96lt1m6's Avatar
WOW you have a cam and no stall. a stock cammed Lt1 needs a stall so i would say that will help you a bunch a 3600 comes to mind
your 60' times must be terrible
Old 02-11-2009, 03:18 AM
robsquikz28's Avatar
x2^ but yeah get a 3600 stall for that cam and gear and u can easily it 12.8x i know of someone similar to ur setup and all day...
Old 02-11-2009, 08:02 AM
3DFORMULA's Avatar
Get that stall. Suspension would help greatly, you could be low 12's if you had both.
Quick Reply: Can I get low 12's?
