Bore increase
Old Feb 9, 2009 | 06:37 PM
96blackta's Avatar
Default Bore increase
I'm having my block bored to 355, and I'm looking into some forged pistons. I'm on a budget, so I'm hoping someone knows a good deal. I'd like to pay around $300, although I know $400 is probably more realistic.
Old Feb 9, 2009 | 06:48 PM
fergymoto's Avatar
These Speed Pro pistons are about as inexpensive as you are going to get at $289 through Summit
http://store.summitracing.com/partde...0&autoview=sku
These Keith Black ones would be next in line at $329
http://store.summitracing.com/partde...8&autoview=sku
Old Feb 9, 2009 | 07:19 PM
96blackta's Avatar
Perfect! I thank you sir.
Old Feb 9, 2009 | 08:36 PM
96capricemgr's Avatar
Too bad both have a thick ringpack that will be more parasitic and cause more bore wear than stock.
Old Feb 9, 2009 | 08:46 PM
fergymoto's Avatar
Hey, he said he was on a budget.
Old Feb 9, 2009 | 09:14 PM
Yeah you gave him exactly what he asked for. I just tried to say he was not taking a step forward as I am sure he would like too.
I am so tired of seeing all these slow "built" motor cars and this is one of the mistakes that leads too it.
As I have said before, it is not cheap to improve on what the factory gave us.
Old Feb 10, 2009 | 10:10 AM
96blackta's Avatar
Why am I being told they're as good or better than stock then?
Old Feb 10, 2009 | 10:19 AM
joelster's Avatar
Forged piston> hypereucraptic all day long , no two ways about it. The guys on a budget there will be some compromises made.
Since when? The factory LT1 is decent, nothing exotic. Go spray a stock LT1 with a 150 shot. You'll get a summer out of it. Go install a 4-5psi blower on one, you'll get a summer out of it. I know of several cast crank 383's with h-beams and forged pistons that don't break the bank, and can handle some serious boost or juice. And they were relatively cheap. $1000-$1100 for the internals.
Old Feb 10, 2009 | 10:22 AM
ss.slp.ls1's Avatar
I've seen several 150 shot/stock LT1's last. As long as it is set up right, with timing and fuel, it will last a while.
Old Feb 10, 2009 | 10:26 AM
joelster's Avatar
That is pushing the envelope though. Kinda like running 11's with a 10-bolt, some will last some won't.
Old Feb 10, 2009 | 10:34 AM
RamAir95TA's Avatar
I agree with slp. A friend of mine has been running a 150-shot on a stock engine entirely for 3 years now with no problems. Compression is still strong and within 12psi across the board.
Old Feb 10, 2009 | 10:50 AM
ss.slp.ls1's Avatar
The people who don't last are the ones who don't use a window switch & WOT swich, don't have an upgraded pump or injectors, run a big shot without pulling timing or running high octane fuel.
N2O can be safe, you just have to have your setup made to accommodate it.
Old Feb 10, 2009 | 11:01 AM
kinglt-1's Avatar
Agreed, many don't take the proper steps to setup a nitrous kit safely, then it goes boom and they tell you it was the motors fault.
Old Feb 10, 2009 | 11:32 AM
fergymoto's Avatar
With the budget forged pistons you are taking a step back and a step forward at the same time.
Step back - thicker rings which could cause more wear and will have more drag than the thin metric stock rings. Both wear and power loss would be minimal IMO.
Step forward - stronger pistons that will stand up to more nitrous
You would probably be better off to run a quality set of hypereutectic pistons with the metric rings if you don't plan to use a whole lot of nitrous. Good hyper pistons will take some abuse. The stock ones themselves are pretty good.
Old Feb 10, 2009 | 12:02 PM
joelster's Avatar
Do any of you guys have any first-hand evidence of this "thicker ring pack wear" that "could" occur or is it just internet banter?
Oh, and as for nitrous I should have just said a 200 shot in my first post. The point I was trying to make is that LT1's are a decent motor, nothing exotic, nothing substantial, nothing really out of the ordinary, just a solid 350 sbc with a few quirks. Yes they can be rebuilt for pretty cheap unlike what the taxi driver says.
Old Feb 10, 2009 | 02:17 PM
96blackta's Avatar
That's what I'm saying. Where did you hear all this? If you read it on-line without experiencing it first hand, I'm going to have to say there's nothing wrong with those SPs...
Old Feb 10, 2009 | 02:22 PM
fergymoto's Avatar
It's true but it is so minimal that it doesn't matter IMO. Not the most top of the line ideal way to go, but it will work just fine.
