True dual pipes
Old Feb 12, 2009 | 06:34 AM
jrock692's Avatar
Default True dual pipes
Is this a good setup for my true duals? I have pacesetter lts, and stainless works tubular mufflers, of course no cats. So will this universal kit work for my application? And I will dup it before the axle.
http://www.jegs.com/i/PYPES/958/XVF10/10002/-1
Old Feb 12, 2009 | 07:17 AM
sweet-94z28's Avatar
I don't see why it wouldn't
Old Feb 12, 2009 | 07:43 AM
jrock692's Avatar
just wondering about the fitment. Mainly around the drive shaft/ta area.
Old Feb 12, 2009 | 08:23 AM
seanaugustus's Avatar
Are you going to dump it at the rear end or go all the way back? Go get the universal x-pipe from summit. Its cheaper and vertually the same thing. And yes Im running PS LTs as well
I followed what this guy did to a T.
http://www.lt1engine.com/tech/how-to...duals-exhaust/
Old Feb 12, 2009 | 04:38 PM
Z28_LT1's Avatar
do you have the 3" or did you stick with the 2.5"? Any clearance issues yet? I bught my car lowered and I wanted that setup...
Old Feb 12, 2009 | 05:09 PM
jrock692's Avatar
Okay, with his setup, I still do not quite understand how he hooked the pipes up to the headers. Did he use a reducer and weld it to the pipe and slip it over the collector or did he add a flange to both sides?
Old Feb 13, 2009 | 01:27 PM
I went with 2.5 for torque and ground clearance. No problems to report at this time. Just finished mine a couple weeks ago.
Old Feb 13, 2009 | 01:31 PM
You have to buy the two collectors. What I did since PS LT's are slip over style I bought the two collectors which come with two flanges and bought two additional flanges and welded the flanges to the headers. Helps with removal and installation and also allows you to change to any other exhaust with flanges if you decide to do something different. i.e. H-pipe, straight pipe or straight headers at the track
Old Feb 13, 2009 | 02:02 PM
1slo_camaro's Avatar
From: Born/Raised North East, MD Lived in VA, NC, MI Back in Yorktown, Va
ok not to steal your thread but im curious about True Duals as well. right now im running pacesetter midtubes. i was planing on using my y-pipe and just cutting it so i can run them straight back. what kind of money will i be looking at and parts wise? can someone school me on true duals? please
Old Feb 13, 2009 | 02:37 PM
ss.slp.ls1's Avatar
Depends, are you going to be using hi-flo cats?, bullet mufflers? Dumped or over the axle?
