ls7 lifters
Old Feb 12, 2009 | 10:12 AM
RaM AiR 97's Avatar
Default ls7 lifters
will i be able to use these lifters on my lt1 with out any modifications
http://www.gmpartsdirect.com/results.cfm
Old Feb 12, 2009 | 10:16 AM
94Z28rag's Avatar
Yes and no. They are supposedly the same size, but I've heard that they require slightly longer pushrods.
Get a pushrod length checker. Do a search and you'll see tons of threads on this topic.
Old Feb 12, 2009 | 10:18 AM
Elliott's94Z's Avatar
I'm running them w/ no modifications that needed to be done. I don't like to speak for other peoples cars and so "no you won't" but the odds are you will have no issues. I had to run a smaller pushrod with them.
Old Feb 12, 2009 | 10:32 AM
RamAir95TA's Avatar
I don't know about you, but I'm not about to play the "odds" on my valvetrain. For the peace of mind, investing in a PR length checking tool is a wise decision. And correct me if I'm wrong, but if you're running them with "no modifications" then what exactly is a shorter pushrod considered?
This is good advice.
Old Feb 12, 2009 | 10:35 AM
[QUOTE=RamAir95TA;11038216]I don't know about you, but I'm not about to play the "odds" on my valvetrain. For the peace of mind, investing in a PR length checking tool is a wise decision. And correct me if I'm wrong, but if you're running them with "no modifications" then what exactly is a shorter pushrod considered?
I did check for correct length w/ a measuring tool 3 different times. Never said anything about me not doing so. I consider it to be replacing/upgrading the pushrods for my application, not modifying.
Old Feb 12, 2009 | 10:43 AM
ss.slp.ls1's Avatar
You've got your answer.
Just wanted to add that LS7 lifters are now the new replacement lifters for all small block Chevy's. If you go to the dealer and ask them for LT1 lifters, they will give you LS7 lifters.
Old Feb 12, 2009 | 10:52 AM
Stock PR are 7.200" I had to "modify" mine by going with a 7.15'' Hope this clears my "not having to modify my application" up.
Old Feb 12, 2009 | 11:15 AM
SHDY 5.7's Avatar
Not to kick a dead horse,just clarifying,but u guys are saying that u cannot run these with a stock rod? Damn it. I just got a set,now I have to change rods. I was told I could. Damn it.
Old Feb 12, 2009 | 11:28 AM
ss.slp.ls1's Avatar
You may or may not, you'll have to measure to be sure. The LS7 lifters sometimes require a pushrod that is .05" different.
Old Feb 12, 2009 | 11:35 AM
Yeah it seems hit or miss with these things. When I was first looking into parts for my swap, some people were saying they didn't have to change them out to a different size or yes they did to a longer, then some came in with saying they had to go smaller...
Just measure for correct size to ensure. Pushrods are not that much $$$ in the end. Trickflows are a good PR to go with. Summit sells them for right around a $100-110 bucks a set.
Old Feb 12, 2009 | 11:39 AM
BruceBufferTA's Avatar
I get what you were implying man! When I hear the word modify I think of physically having to tinker with something to get it to work/fit. I also had to use a 7.15'' pushrod for my application.
Pushrods are cheap. $100 dollars isn't that bad plus you will have a lot better rod over the stock.
Old Feb 12, 2009 | 11:50 AM
ss.slp.ls1's Avatar
Summit sells the TF chromemoly pr's for $87 a set. Hard to beat!
Old Feb 12, 2009 | 11:52 AM
Man is that all! Not bad..I thought they were around a 100 or so. Can't go wrong with that price tag.
Old Feb 12, 2009 | 12:03 PM
ss.slp.ls1's Avatar
Yep, that's what I'm running.
Old Feb 12, 2009 | 12:08 PM
RaM AiR 97's Avatar
the reason i asked is because the lt1 lifters are like 100 dollars more than the ls7s. I just called up a buddy of mine and he said to go with the stock ones because he has heard and seen the the ls7 s sometimes fail.
Old Feb 12, 2009 | 12:15 PM
I have never once heard of the LS7 lifters failing..
Old Feb 12, 2009 | 12:17 PM
ss.slp.ls1's Avatar
Your buddy is spreading rumors. You'll be fine with LS7 lifters.
Old Feb 12, 2009 | 12:25 PM
SHDY 5.7's Avatar
Ok. Guess ill just measure and from there.
Old Feb 12, 2009 | 12:51 PM
rickreeves1's Avatar
Anyone know where to get these locally? Can't wait on parts with a daily driver.
Old Feb 12, 2009 | 12:57 PM
Paul Bell's Avatar
That's MISTER MODERATOR
Here's a question: What's so good about the LS7 lifters over others or even the original LT1 lifters?
