auto meter tach
Old Feb 12, 2009 | 10:07 PM
mistamista's Avatar
Default auto meter tach
when installing do you have to cut the brown or orange wire on the back for some reason mine is not reading right it's like 1k above my factory one
Old Feb 13, 2009 | 07:59 AM
sepno77's Avatar
did you hook it up to the coil or the ecu?
Old Feb 13, 2009 | 03:10 PM
chrisLT1's Avatar
on an LT1 car its the black and white wire
Old Feb 13, 2009 | 03:11 PM
phirepower's Avatar
ECU was the easiest, it is a white wire , I can look up the exact one and location when I go home
Old Feb 14, 2009 | 02:31 AM
mistamista's Avatar
im not sure it is the red wire on the top left side of the intake manifold is there a better place to hook it up
Old Feb 14, 2009 | 08:58 AM
ws6chicken's Avatar
+1 the instrument cluster tach signal, the white wire, from the PCM (C1 the red one, pin 13). I tapped mine at the PCM connector, its only a signal for the cluster so it will not effect any engine rpm reading the computer needs.
Old Feb 14, 2009 | 11:09 AM
baylove's Avatar
OK so is it better to hook it up on the coil ?? if so what wire i had mine hooked up to pcm but for some reason it made the fuel pump cut off so i dissconnected the tach
Old Feb 14, 2009 | 01:14 PM
ws6chicken's Avatar
BTW my application was getting RPM to a racepak unit.
that white wire on the PCM sole purpose on the car is to get a tach signal to your dash. Thats why I did not even contemplate going to any other sources for a rpm signal. So to answer your question I think it's better to get from the PCM. as to why your fuel pump would cut out, you might of messed up the fuel enable that is on the same connector and wire bundle as the instrument cluster tach sig at the PCM.
Old Feb 14, 2009 | 02:01 PM
Formula350's Avatar
BLUE WIRE CUT THE BLUE WIRE DAMNIT!
Sorry had to. I'd much prefer the coil signal over the PCM's. Reason, being your signal from the PCM is most likely going to be different from the actual RPM simply due to all the processing and changes in electrical signal after passing through the PCM. Everyone says their Tachs in F-Bodies are 100rpms off, yet my tach is DEAD ON THE NUTS! Maybe it's because I have a 93 and no PCM, which I think the RPM is direct from the coil (or just a pass-through in the ECM) as when I hook my scanner up to the ECM and run down the road it's right on with my tach.
Anyways, that's just my $.02
Old Feb 15, 2009 | 10:55 AM
sepno77's Avatar
+1 on this one. i hooked mine up to the coil and it works perfect. this is a good option to ur problem.
Old Feb 16, 2009 | 04:37 PM
paul12001's Avatar
Im having the same damn problem
paul12001's Avatar
I think i blew a fuse or sumthing
Old Feb 16, 2009 | 06:42 PM
camar0corey's Avatar
In all three fbodies I've owned I always hooked it to the coil, seems like its the best way to go.
Old Feb 17, 2009 | 09:56 AM
chevy42083's Avatar
Mine runs from the tach signal from the PCM to the Autometer tach. Shouldn't have to cut any of the wires on the tach.
