jet hot LTs
Old Oct 10, 2003 | 08:01 PM
WLRIII's Avatar
Default jet hot LTs
Is there anyway that i can get jet hot longtube and still keep the cat so i stay emissions legall
Old Oct 10, 2003 | 10:28 PM
Gangly's Avatar
Default Re: jet hot LTs
yes, you can still put a cat on the exhaust but it would have to be an aftermarket cataytic converter. just put it on the y-pipe or after the y-pipe.
Old Oct 10, 2003 | 10:43 PM
BizZzatch350's Avatar
Moderator
Your going to have a custom Y pipe made, there is plenty of room for a dual cat set up using after market cats since they are so small.
Old Oct 11, 2003 | 01:40 PM
WLRIII's Avatar
so which one is it can i just use an aftermarket y-pipe with some cats or do i have to get a custom made y-pipe
Old Oct 13, 2003 | 01:06 AM
Gangly's Avatar
Sorry, I assumed you knew that with longtubes you have to get an aftermarket y-pipe, there is no other way. Just put the aftermarket catalytic converter on the y-pipe or right after it. It doesnt really matter where other than the fact that the closer to the headers the better it will function.
Old Oct 13, 2003 | 12:27 PM
GreekZ's Avatar
Would a hooker ypipe work on Jethot Longtubes?
