Anybody done their rear brake lines all the way from distribution block to caliper?
Looking at the kits, seems they're just for the rubber sections with the banjo bolt. I wanna go from the distribution block out to eliminate the hard line. Someone have a solution or do I need to disassemble and try to figure it out? Would like to put adapters in the calipers and distribution block and just run AN hose.
Eliminate the hard line? With what, rubber all the way to the calipers? I have to run new lines since I replaced my rear, but I've yet to get around to that. I'm curious as to why you don't want the steel lines. They'd last longer than rubber, unless you rarely drive it and it doesn't see much of the elements.
Moderator
I cant really see the point in doing that, most people would just make new hard lines if so inclined. But your right, most 5 line kits, replace the rubber lines, the four that run to the calipers and the one rubber line in the rear. We did that last weekend on my TA with a Kore3 5 line steel braided brake line kit.
Well my main reasoning was the original hard line is kinkier than heels in the bed. So I thought some SS braided hose would look nice and be friendlier. I figured this thread wouldn't get much traction so I removed the banjo bolts and the connection at the distribution block to figure something out. I wouldn't have a huge problem with bending new hard line but I really like the idea of a flexible hose in case it does need to bend or move.
Location: Born/Raised North East, MD Lived in VA, NC, MI Back in Yorktown, Va
1 Post
X2 i want to redo my brake lines. or has anyone ever looked into relocating their abs unit? im trying to clean up my engine bay. i havent got around to the wiring yet but i wanna do all that and clear up the brake lines. and was thinking about relocating my ABS to were the air filter drops down in. and stealing someones idea on here and run my filter down the front of the radiator or coming up with the money to throw on a SS hood and all. (sorry to run off track with the thread but it all ties together i guess)
My dad always said that ABS just insures what you're about to hit, you hit it head on. I'll take my chances on locking the brakes--at least it's all stopped rolling by this point.
ive done thousands of brake lines just put the steel line all the way back, but leave the rubber hose on the rear so it will flex to remove the calipers when doing brake work because if you dont one day that line may snap due to flexing from the weight of the caliper.....or for cool factor you can a nice ss line there if youd like it wont hurt anything.
As for the abs its all preference do you want it or not,you dont need it all but it can and will help you out if you need to stop fast.....its all about is it a daily driver, are you a highway driver, city driver, drive like a jag..do you want them or not is just the main preference.....weight isnt really there like only a 10lb difference....
I'm going to be making custom brake lines pretty soon for my fab 9" since the stock lines don't really match up well. I would NOT recommend replacing the whole rear brake line with braided hose or rubber hose. Any type of flexible hose like that is prone to expanding under high brake pressure. So basically you could get a spongy brake pedal or never be able to achieve max brake pressure. Do all hard line on the rear axle but do stainless braided flex line for the small section to the calipers.
I've found a decently priced place called "inline tube" that sell straight 6ft long hard line. Just get two of those for each side of the distributor block and bend them.
And I'm sorry but that makes no sense. The whole point of ABS is to be able to turn and avoid an accident when your braking hard. A non-abs car under hard braking will lock the brakes and skid straight ahead, not being able to turn to avoid anything. Now I will agree a skilled driver in a non-abs car can stop the car sooner and turn the car better than an idiot behind the wheel of an ABS car. But as we know, there are a lot of idiots our there.
LS1TECH Sponsor
When I installed my manual brake master cylinder, ran new lines through out the car with RJ Race Cars brake line kit. If you are converting to standard fittings and not the metric crap, this is the way to go.
http://www.quartermax.com/details.ph...e%20line%20kit
Jon
Jon
__________________
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
Jon
Jon
Well shortly after, I found these puppies http://store.summitracing.com/defaul...641431&FROM=MG. Some 90* fitting teflon hose like this http://store.summitracing.com/partde...039-24&FROM=MG will do the trick.
