So what do i do next????
Old Feb 15, 2009 | 09:00 PM
AChotrod's Avatar
Default So what do i do next????
Next on my list is a clutch, but what can I do besides bigger cubes and swapping cams or N2O for more power. I think Im at a wall and should consentrate on other areas of the car now????What do you guys think?
Current mods
Factory Ram air with K&N filter
LE2 heads w/ patriot gold dual springs
CM push rods,TFS guide plates
LE custom cam 230/236
LE ported intake
58mm BBK TB
1.6 pro mags
LPP LTs
3" True duals
37lb injectors
EWP
BBK pulley
Plugs /wires
Built and dyno tuned by Speedinc.
Last dyno was 413.66rwhp/366rwtq b4 the TDs
Suspension mods are
SFC
TA
LCA
PHB
STB
on WS6 suspension and Dana S60 with 4.10s and 315 nitto DRs
Any help or tricks would be great!!!
Old Feb 15, 2009 | 09:02 PM
1badzee's Avatar
Sell it and buy a ZO6 or something....
Old Feb 15, 2009 | 09:06 PM
AChotrod's Avatar
LOL! Never!
Old Feb 15, 2009 | 09:10 PM
z28rob18's Avatar
tubular front suspension and some weight reduction. o and shocks
Old Feb 15, 2009 | 09:14 PM
StealthFormula's Avatar
Weight reduction, getting rid of the Nitto's for M/T's would make the car a little faster but no power gains. Maybe Aluminum Flywheel and LS1 DS to free up a couple ponies, maybe the TB Bypass which is simple to do and dyno proven to give 5-6rwhp. Could do more suspension like k-member, lca relocation brackets, shocks and drag springs etc. etc.
Old Feb 15, 2009 | 09:16 PM
z28rob18's Avatar
th350 with a transbrake
Old Feb 15, 2009 | 09:21 PM
Jeff400w's Avatar
How long before you can get us some track times on your new setup AC?
Winter is getting old here, how about you?
Old Feb 15, 2009 | 09:22 PM
myltwon's Avatar
+1 and some real tires!
Old Feb 15, 2009 | 09:29 PM
vanilla89's Avatar
X2 on the shocks. I just ordered some qa1's for mine.and maybe some LCA relocation brackets..
Old Feb 15, 2009 | 09:40 PM
AChotrod's Avatar
Already have the TB by-pass and cant use LS1 DS, I have a S60 and a Strange DS rated to 800hp. I would have to cut down a stock shaft and worry about it snapping
Nittos are my street/strip tires and when i pick up some drag rims they will get MTs.
Is there anything more I can do for power???
Suspension is on the short list after the clutch.
Old Feb 15, 2009 | 09:42 PM
AChotrod's Avatar
I hate winter!!! We tried so hard to get the car done for the last weekend and the damn track closed for no reason.
z28rob18's Avatar
id say spray it some other then that more cubes bigger cam and all lik u said
Old Feb 15, 2009 | 09:45 PM
AChotrod's Avatar
Im builing a 396 with spray and that will need a new cam anyways now.
Trying to figure out how to get more out of what I already got.
Old Feb 15, 2009 | 09:47 PM
Elliott's94Z's Avatar
+1 Took the words right out of my mouth
vanilla89's Avatar
Ya, spray it..
Old Feb 15, 2009 | 09:50 PM
AChotrod's Avatar
I think clutch+spray= mid 10s as is!! Thats very very tempting.
Old Feb 15, 2009 | 09:51 PM
AChotrod's Avatar
Originally Posted by vanilla89
Ya, spray it..
Is that Lloyds car in your pic?
Old Feb 15, 2009 | 09:58 PM
zigroid's Avatar
if I were in your position...
I would get in touch with EFI connections about their cam sensor and such that allows you to run a SBC with an LSx PCM. I would buy an aftermarket SBC block, run 427-434 cubes, some kickass heads, a big solid roller, single plane intake with an elbow, and make 650-700 hp while keeping the RPMs at a reasonable level.
in order to make a lot more power than you're making you're going to have to convert SBC parts. why not just go the other way around and end up with something better?
Old Feb 15, 2009 | 10:14 PM
AChotrod's Avatar
Becuase Im an Lt1 fan and I know its as capable to make the power I want! 1000rwhp is not impossible with a LT1 and thats far beyond my goals.
I may end up switching to carbs someday though.
Old Feb 15, 2009 | 10:35 PM
ThoR294's Avatar
buy you and I some strano sprigns and koni 4/4s
