Kooks Headers and fitment issues
Old Feb 17, 2009 | 10:35 PM
FIuser's Avatar
Default Kooks Headers and fitment issues
I am considering some Kooks headers and y pipe. I am curious to know about fitment issues with either the 1 3/4 header or the stepped header 1 3/4 to 1 7/8. Both will end in a 3 inch collector. I would like to know if anyone has experience with either header and if there are fitment issues? Also concerned over ground clearance.
Thanks for your time.
Old Feb 17, 2009 | 10:48 PM
FlamingChicken's Avatar
i have the 1.75 and never had a problem with clearance. the collectors tuck very well. only issue was when i switched to a canton pan the oil level sensor didnt fit.
Old Feb 17, 2009 | 11:22 PM
94Zstangwalker's Avatar
ive herd of people having a LOT of trouble getting these installed.
Old Feb 17, 2009 | 11:44 PM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY, Dalton GA, Nashville, TN & Atlanta, GA
I have 1 3/4" Kooks, and their offroad Y-Pipe. Mine fit like a glove, and went in without issue. My understanding is they offer the best ground clearance of any widely available LT1 header. If your car has the factory oil cooler, it will have to be removed due to the fact they tuck up so tight to the block.
Old Feb 18, 2009 | 07:38 AM
ABA383's Avatar
I've got the stepped 1 3/4-1 7/8" and they fit great. I only had to slightly touch one of the steering knuckle bolts with a grinder because there was slight contact when turning. MIne also have the A.I.R. fittings which is a nice plus because of visual emissions inspections up here. They fit great, have terrific ground clearance and work well. I have to use the small PF454 oil filter which is no big deal.
--Alan
Old Feb 18, 2009 | 07:37 PM
FIuser's Avatar
Great, thank you for the reply.
Since I have an audience, do you guys think that a single 3 inch pipe will be a restriction if I am looking at a AI head and cam package?
Thanks again.
Old Mar 9, 2009 | 09:05 AM
T/A KID's Avatar
Bringing this back
Went to drive my Procharged setup yesterday and the linkage is rubbing my 13/4-17/8 kooks headers pretty bad???
I am running stock motor mounts and a BMR k-member and Kooks just told me since my setup is highly modded that is probably the reason it is not fitting .
Do you guys with Kook stepped headers care to post pics of were the #1 primary is near the steering linkage.
My friend and I do not want to mess with the linkage (grinding) if all possible. I don't really feel safe doing so
THANKS FOR ANY HELP FELLAS
Old Dec 19, 2009 | 12:00 PM
Rumblin70ss's Avatar
--Alan
Alan,
Do you have a factory oil cooler on your car by any chance?
Thanks,
Tony
Old Dec 19, 2009 | 02:29 PM
AChotrod's Avatar
I hear their stepped headers have some issues, and there 1 3/4 headers fit pretty good.
Old Dec 20, 2009 | 10:10 AM
ABA383's Avatar
Originally Posted by Rumblin70ss
Alan,
Thanks,
Tony
I don't have the factory oil cooler...I think that is where some of the fitment issues are..My stepped headers fit right in with no clearance issues..I've had them for a bit over two years and they still work great and have that golden brown hue that uncoated stainless gets...
--Alan
Old Dec 20, 2009 | 12:48 PM
--Alan
Thanks Alan! If I order them I guess I'll have to be aware I might have to remove the oil cooler!
Old Dec 20, 2009 | 05:08 PM
BTC's Avatar
BTC
I don't think there is any doubt that the oil cooler will have to be removed if you get Kooks headers. I removed my oil cooler, and I'm running a short filter. I don't see any way that there would be room for the cooler running those headers. The upside is that they tuck up really nice.
Old Dec 21, 2009 | 07:28 AM
It looks like I'll have to remove the cooler if I go with these even though I was trying not to. A small price to pay for an excellent exhaust system though. Did you have the moroso style cooler on yours?
Old Dec 21, 2009 | 09:16 AM
wrd1972's Avatar
The oil cooler must come off and you cant run the tall filters either.
Old Dec 21, 2009 | 11:05 AM
BTC's Avatar
BTC
If the Moroso was the earlier, shallower of the two LT1 oil cooler designs, then yes.
Old Dec 21, 2009 | 11:45 AM
djjab57's Avatar
I think the cooler has to come off with most LT's. I am going to get rid of my Jet Hots and get some kooks myself
