Cam rev range CC306
actually saw your dyno graph on another forum
where as here is a gm847, which is closer to what I was talking about
Some guys swear the XFI 292 peaks in the low 6000s but another guy has a graph of it not yet peaked when the pcm ran out of rpms up over 7000rpms.
People also like to ignore critical details, ported heads, different intakes, header seletion all tweak rpm range, then there are the guys who try and compare without regard to displacement.
On a properly setup 350/355 car a mid 220s intake duration cam is going to peak over 6000rpms and need to rev several hundred rpms beyond that for best performance.
Start choking things with bad intake or exhaust, use bad programming, insufficient or worn out springs, missadjusted valvetrain etc. can all screw that up and examples of that just prove a problem with the car, not the rpm range for the cam.
i highly reccomend running 6 qts in any lt1
