Does anyone have a good right up for removing heads
Hey since my lt1 decided to blow a head gasket is there a good right up on how to remove the heads. Also is there a good wright up on port and polishing heads.
This is what I used During my head swap:
http://www.afrashteh.com/guide/install.htm
Give Ai a call for one of their h/c packages.
its pretty easy and straight forward. like said get a haynes manual. the bad thing about the manual is it will tell you to do alot of things to do that makes it "easy" but time consuming. i pulled my heads with studs, engine in the car in about 4 hours. just take your time and stay organized.
Unless you're a professional and have all of the proper tools and experience, I wouldn't try porting your heads yourself. It's an artform and takes years of experience. You're better off sending them to AI or LE.
and for porting, LE or AI. dont play around with that science
